Diesel Forum - TheDieselStop.com - View Single Post - Run used oil
Thread: Run used oil
Old 08-25-2006, 07:12 PM   #12 (permalink)
Fever
Fever's Avatar
My Photos: (9)
Send a message via ICQ to Fever
Re: Run used oil
Ok, but a micron is 39 millionths of an inch. And don't the fuel filters on our trucks filter to 20 microns? Seems that unless the fuel we put in is really really clean our injectors are on borrowed time anyway. If I run waste oil through a sub-micron filter and put in one gallon per tank I just can't see it causing problems. I could be wrong, but that's the way I see it.
-john
I'm confused....You're talking about 1 gallon of waste oil per tank of fuel?...
Why on earth would you risk $2,000+ in repairs to save $3.00 per tank full??
2002 F-250 Super Duty Super Cab Short Box 4x4
7.3L PSD, 4R100 Automatic, 3.73 LSD Gears,
BTS Valve Body Kit, Tymar Intake, Muffler Delete,
DP Tuner F-5 (60T/80E/120R/Hi-Idle),
ISSPro A-Pilar Guages (Pyro/Boost/Trans Temp),
Powerslot Cryo Rotors/Hawk LTS pads,
285/75-16 Yokohama GeoLander A/T II Tires,
Tekonsha Prodigy Brake Controller
2006 Sunset Creek 269BH Travel Trailer
Fever is offline   Reply With Quote
