Diesel Forum - TheDieselStop.com - View Single Post - Run used oil
Thread: Run used oil
Old 08-25-2006, 07:22 PM   #13 (permalink)
jas10
My Photos: (21)
Re: Run used oil
I'm not convinced I'm running such a risk. As for the reason, I live 40 miles from the nearest place that will take waste oil. I can use up valuable garage space saving it until I'm ready to take it somewhere, I can store it outside the garage and make my place look like a junkyard, I can pour it on the ground and pretend it doesn't make a difference, or I can burn it in small quantities in my truck. Up until now, I've just saved it up and taken it into town when convenient to a garage that burns it in their heater. I'm not convinced that I will burn it in my truck. I don't want to do something stupid, but if it is ok to burn it would be the simplest solution. I did burn used oil in my 12-valve Cummins, but its mechanical fuel system was somewhat more forgiving than HEUI.
-john
1999 F-350 6-Speed SRW CC LB 3.73
jas10 is offline   Reply With Quote
