Re: Run used oil
I'm just in awe here... Even if you could demonstrate that the used oil could be filtered to a safe level, and then demonstrate a need to pour it into the tank, I still wouldn't do it on principal alone.
Things you can do with used oil:
Recycle it (there's a thought)
Send it in for analysis.
Kill weeds with it.
But then again, I just had lunch with a Duramax owner (I wore a disguise) and he's certain that K&N is the best air filter ever, and nothing makes a Duramax purr like a bottle of ATF in the tank... Everyone has their own Kool-Aid to drink, it's just what flavor we like.
2002 F-250 7.3L Lariat CC 4X4 Off Road, AFE Stage II w/PG7, MagnaFlow Performance Turbo Back, DP Tuner F6, ISSPRO EV Gauges, DS HX Mod, MIAH Delete, Foil Delete, DS A/C Mod, DS Coolant Bypass Filter, 203º T-Stat W/Billet Housing, Evans NPG+, V-10 Tranny Cooler, Mag-Hytec Tranny Pan and Front & Rear Diff Cover (3.73 LS), Magnefine Filter, Sonnax Valve-Tricumulator Springs, Amsoil end to end, Astro Tonneau Cover, BedRug, Bilsteins, Rancho Steering Stabilizer, EBC Rotors/Yellow Stuff, Driiv Off Road 18x9 wheels, Michelin LTX A/T2 275/65R18, Balance Masters Dynamic Wheel Balancers, Gentex NVS Mirror, ExpressRC ((XM)), Garmin StreetPilot 2720
The two best days a PowerStroke owner can have... When the last payment is made, and when the warranty expires...
PowerStroke ownership is neither for the faint of wrench, nor the thin of wallet...
