Re: Run used oil
I'm not convinced I'm running such a risk. As for the reason, I live 40 miles from the nearest place that will take waste oil.
If you change oil on a regular schedule (3000-5000 miles), they you'll be changing maybe once a quarter, which amounts to one 5 gal bucket of waste oil. And you're saying you can't get by that recycle place once a quarter? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
When I weigh that "inconvenience" against the possible damage to a set of injectors, even the cost of running that 40 miles immediately after changing the oil makes sense to me.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version  ), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
