Re: Run used oil
Ok, but a micron is 39 millionths of an inch. And don't the fuel filters on our trucks filter to 20 microns? Seems that unless the fuel we put in is really really clean our injectors are on borrowed time anyway. If I run waste oil through a sub-micron filter and put in one gallon per tank I just can't see it causing problems. I could be wrong, but that's the way I see it.
-john
Your math is a little off. There are 25400 microns per inch. Most fuel filters for diesel, at the engine, are 2 micron filters. Is it that the oil is hard to dispose of or is 3.75 gallons of old oil, worth about 12 bucks as fuel if that, financially important to burn as fuel every 5K miles?
2002 F250 7.3L PSD, bought new now at 195K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
