Re: Run used oil
Ok, this answer is coming from a Tech from Freightliner who I trust completely.
You can't filter the impurities, dirt, metal etc down enough to where it won't harm these newer injectors & do it affordably. In the old days it was common practice. Also, you cannot remove the HIGH acid levels found in WMO by filtering, which also damage injectors. Also, the additive packages being used in todays diesel oils are designed to not burn under heavy load, high compression diesel engines. The additives are non combustable & flat out don't burn, in order to protect the internal parts of our engines. Since it doesn't burn easily & needs to be mixed with diesel to even pass it through the engine. Then it produces less power which requires more of it. So the savings are even less.
It's just a bad idea & not just for one, but for multiple reasons.
My Photos----- BTS BUBBA "Life Member"
2002 7.3L Excursion 4x4, FTVB, MBRP 4" SS Exhaust, Rancho 9000X shocks, "V" code Front Springs & "B" Code Rear Springs, Ride Rite AirBags, Rear Hellwig Swaybar, Cut Front BumpStops, DieselSite Ext Trans Filter Kit - Coolant Filter Kit & 203 stat, "Scotpart" mod, "Hutched & Pooned", "LandYot" Radius Rods US Gear Overdrive 75mph @ 1750rpm's
2001 7.3L F350 CC LB 4x4 5" Exhaust, pillar guages, BTS Trans, US Gear Underdrive, DP 6 pos chip, V10 Trans Cooler, DieselSite - Coolant Filter Kit, Evans Coolant, 203 stat, DI reg Fuel Return, GT38R BB Turbo, AFE 2 Intake, Banks Intercooler, Air Rite Bags,
2000 Excursion Limited V10 4x4 7" Lift
"Family of 5 saved by Grace"
