Diesel Forum - TheDieselStop.com - View Single Post - Run used oil
Thread: Run used oil
Old 08-26-2006, 07:08 PM   #27 (permalink)
StorminNorman
Re: Run used oil
Ok, this answer is coming from a Tech from Freightliner who I trust completely.
You can't filter the impurities, dirt, metal etc down enough to where it won't harm these newer injectors & do it affordably. In the old days it was common practice. Also, you cannot remove the HIGH acid levels found in WMO by filtering, which also damage injectors. Also, the additive packages being used in todays diesel oils are designed to not burn under heavy load, high compression diesel engines. The additives are non combustable & flat out don't burn, in order to protect the internal parts of our engines. Since it doesn't burn easily & needs to be mixed with diesel to even pass it through the engine. Then it produces less power which requires more of it. So the savings are even less.
It's just a bad idea & not just for one, but for multiple reasons.
Very good answer. I am certain it will be ignored by many. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
StorminNorman is offline   Reply With Quote
