Diesel Forum - TheDieselStop.com - View Single Post - Run used oil
Thread: Run used oil
Old 08-30-2006, 02:45 PM   #34 (permalink)
spg
Re: Run used oil
I don't beleive that properly filtered uncontaminated WMO and or Transmission fluid run in a 10 to 15% blend will hurt anything at all. It should be filterd to at least 2 micron and not be contaminated with any water or antifreeze. It will definitely burn, it comes from the same oil wells as #2 diesel. As for contaminents it can't be any worse than WVO out of a cooking source. The fuel that we pump from the stations every day would probably suprise you if you had it checked also for dirt and water. Not everyone uses just diesel crankcase oil there are many sources of gas motor used oil.
2001 International 4700LP T444E 210HP Fuller Six Speed 3.38
spg is offline   Reply With Quote
