Chip Test Info - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > General Discussion > News, Comments, and Suggestions
News, Comments, and Suggestions Discussion of TheDieselStop.Com itself. What do you like or don't like, kudos and complaints, comments and suggestions.
Old 01-21-2001, 01:12 PM   #1 (permalink)
JLester's Avatar
Re: Chip Test Info
I just posted an Excel spreadsheet with the raw numbers in our downloads section. Feel free to download and check it out. I wouldn't make a buying decision based on that data quite yet though. We will explain why we did some things that we did in the full article in the next couple of days.
All the numbers in the spreadsheet are taken at 65 mph. I would expect the numbers to go up quite a bit at lower speeds (this follows what we saw on the dyno for the chips that we could pull down to 55 mph without overheating the EGTs).
More later.
<UL TYPE=SQUARE>
<LI>Chip Test Spreadsheet - Right-click and choose Save to download or Open to view.[/list]
Jason
Ford-Diesel.Com Webmaster
2000 F-350 Crew Cab Dually Lariat 6-speed 4x4
Black/Tan 4.10LS Fully-Loaded
JLester is offline
Old 01-21-2001, 02:59 PM   #2 (permalink)
Re: Chip Test Info
Jason,
Was the Hypermax chip you tested a Max chip 300 or the Max chip 330 ? Did you get torque readings for the different chips? Either max or at your 65mph test speed?
BEN
00 F250 XLT PSD 4X4 SC LWB 6SPD 3.73LS ISLAND BLUE; OFF ROAD; CAMPER; TRAILER TOW; POWER TT; ROOF LIGHTS; PILLAR MOUNT ISSPRO BOOST & EGT GAUGES; K&N AIR FILTER
00 F250 XLT PSD 4X4 SC LWB 6SPD 3.73LS ISLAND BLUE; OFF ROAD; CAMPER; TRAILER TOW; POWER TT; ROOF LIGHTS; PILLAR MOUNT ISSPRO BOOST & EGT GAUGES; K&N AIR FILTER; JARDINE 4" EXHAUST
Hypermax 300 hp chip (DAC3) FUEL LINE AND TANK MODS,H/X MOD
BENSFORD is offline
Old 01-21-2001, 03:14 PM   #3 (permalink)
JLester's Avatar
Re: Chip Test Info
I'm assuming the Hypermax chip was the 300 version. It didn't say for sure though. I believe they recommend other mods for the 330 chip. I hope to talk to Max tomorrow to find out for sure.
The only measurements we have are horsepower. You can calculate torque based on horsepower and rpms though. I'm not sure how accurate it is, but it should get you close.
Jason
JLester is offline
Old 01-21-2001, 03:43 PM   #4 (permalink)
Re: Chip Test Info
I'm having trouble opening your spreadsheet file. I don't know if it's my software or your file. Any chance of posting another file in some other format? Anyone else having trouble with the file?
'99 F-250, Reg Cab, SRW, LB, 4x4, 6-spd, XLT
'01 F-350, CC, DRW, LB, 4x4, 6-spd, Lariat, both AMSOIL front to back
Frank Weston is offline
Old 01-21-2001, 03:53 PM   #5 (permalink)
Re: Chip Test Info
Looks to me like TTS, Hypermax, and BD Power X won hands down. The TTS and Hypermax chips where strong in both tests making them the all-around winners in my book. I bet they'll be getting lots of orders on Monday
Another thing I found interesting is that the truck made less power with the boost tube installed. Doesnt surprise me.
'99.5 F350 CC SWB 4x4 6-Speed, 4 Exhaust, K&N, 315/75/16 BFG AT TKOs on 16x10 Eagle 589s, 4 SkyJacker, Trailboss Brushguard, don't need no stinkin' chip
cs_rs is offline
Old 01-21-2001, 03:54 PM   #6 (permalink)
Re: Chip Test Info
File opened fine for me. PRINTED OK TOO!
BENSFORD is offline
Old 01-21-2001, 03:59 PM   #7 (permalink)
JLester's Avatar
Re: Chip Test Info
Any spreadsheet program should be able to open Excel files I would think.
Jason
JLester is offline
Old 01-21-2001, 04:26 PM   #8 (permalink)
JLester's Avatar
Re: Chip Test Info
I'm not sure if I would say they won "hands down". If all you look at is max hp at 65 mph, they did. The important thing to remember is that these results only show hp/egt at one specific rpm and speed. We were indeed impressed by both the Hypermax and BD Power chips.
None of the chips have actually been run on the street except for the BD Power X Chip and Western Diesel Turbo Chip. I have been running the WD chip for a couple of months. We put the BD chip in after the test was over to see what it felt like. I think the test almost brings up more questions than it answers. I'm even more anxious to test them all on the street now. Just FYI, the seat of the pants street test between the BD Power and WD chip was that the WD seemed to come on a little faster while the BD definitely made more top end. I think we will find this to be true among the majority of the chips. Different strokes for different folks I guess. I believe the street test will answer a lot of questions though.
Jason
JLester is offline
Old 01-21-2001, 06:10 PM   #9 (permalink)
Re: Chip Test Info
My software must be screwed up. I did manage to get a look at the first page of the spread sheet using the Windows "Quick View" function. No RPMs were given on that page. What gear did you run in and what was the RPM at 65mph?
Thanks, and good luck sorting out the results.
Old 01-21-2001, 06:16 PM   #10 (permalink)
Re: Chip Test Info
Jason,
Quick question. Are you going to run a street test with the 16 chips? If you are when?
BEN
BENSFORD is offline
Old 01-21-2001, 06:42 PM   #11 (permalink)
JLester's Avatar
Re: Chip Test Info
The tests were run in 5th gear (1:1), I'll have to check the RPMs and give them to you, we didn't write it down during the test.
We will be running a street test with most of the chips. We'll definitely be towing with them, I'm not sure if we'll be testing empty performance yet or not.
What other tests and info would be useful to you? I can see us possibly putting on an exhaust and testing again in the future.
Jason
JLester is offline
Old 01-21-2001, 06:43 PM   #12 (permalink)
Jeremy's Avatar
My Photos: (13)
Re: Chip Test Info
Jason, is your truck a DAC3?
thanks
Jeremy
11 F350 CC King Ranch Auto 4x4 stock for now
07 F350 CC King Ranch Auto 4x4 PHP FICM, PHP Gryphon Custom Tuner
06 F250 SC XLT Auto 4x4 LWB 3.55 gears, PHP FICM, CTS Juice(with PHP custom tunes), studs, EGR Delete.
05 Excursion Eddie Bauer Auto 4x4 PHP FICM, CTS Juice(with PHP custom tunes), Studs, EGR Delete, ctperformanceinc's XF suspension mods
00 F350 CC Lariat PSD 4x4 PHP Gryphon Custom Tuner 6 speed, US Gear OD(dead looking for parts),
94 F-Superduty PSD 5 Speed 12' flatbed
93 F-Superduty 7.3 IDI N/A 5 speed 12' Dump box 60,000 org. miles
Thanks to:
Power Hungry Performance
and
CTperformanceinc
My photos
Jeremy is offline
Old 01-21-2001, 07:07 PM   #13 (permalink)
JLester's Avatar
Re: Chip Test Info
XPC4 is my code.
Jason
JLester is offline
Old 01-21-2001, 07:24 PM   #14 (permalink)
Re: Chip Test Info
Jason
[/B][/QUOTE]
Fuel consumption is always a concern, although I don't know how you could accurately check that without lots of hours per chip.
2000 PSD SC 4x4 manual,XLT, 6sd, 3.73 rear-end, Line-X bedliner, Firestone Ride-Rites with Air Lift load controllerII, AutoMeter gauges, Putman XDR class V receiver, Alpine speakers, aux backup lights. Western Diesel chip. Hypermax downpipe w/Allied muffler. Mag-Hytec differential cover.
2000 F350 PSD SC 4x4 manual,XLT, 6sd, 3.73 LS rear-end, Line-X bedliner, Firestone Ride-Rites with Air Lift load controllerII, AutoMeter gauges, Putman XDR class V receiver, Alpine speakers, aux backup lights. Western Diesel chip. Hypermax downpipe w/4 Auto-Jet offset muffler and tailpipe. Mag-Hytec differential cover. WD TurboBrake.
TonyS is offline
Old 01-21-2001, 07:42 PM   #15 (permalink)
Re: Chip Test Info
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by JLester:
Jason
<HR></BLOCKQUOTE>
To be honest, I'm real disappointed you were able to only get one data point on the limited number of chips that kept the EGT within safe limits. I'd like to see runs at 200 RPM increments from about 1500 RPM to about 2900 RPM for each chip. Note the power at which 1300 EGT is reached. This kind of data would give a real useable power curve. I know you'd probably have to be on the dyno for a week, but that's what I'd like to see.
As far as seat of the pants tests,hook a heavy trailer and climb a long steady grade. Make the trailer heavy enough so that max EGT is reached at a reasonably slow speed. Record the max pulling speed at 1300 EGT for each chip. It might also be interesting to see what kind of hp you'd get testing acceleration unloaded with a G-tech, although this can get pretty hard on the truck.
