Just found a terrific "Tool"!!!!!!!!!!!
It's actually a book! It's called "Pocket Ref". It's a pocket reference book that has info on literally everything!! Torque specs, HP vs. Tq formulas, first aid, screw pitches and thread strength, Pipe sizes, pressure ratings, frictional losses, Math formulas for every concievable shop question, and coversion tables to match, fuse box wiring, rated loads of different size/type of wiring,
It has a whole chapter on saw blades and cutting wheels, it can even show you how to figure out what an electric pump costs per hour to run! It tells you the strength of various angles for triangulation, it even tells you how to read clouds, every area code in the world, as well as time zones, zip codes, all kinds of stuff.
It tells you how to measure a tree and figure out how many board feet of lumber there is before you cut it down, Tells you how to wind a coil, tells you about batteries and their capabilities,
It even tells you how to rate Hurricanes, Tornadoes, Earth quakes, Tidal waves,
How to rate the strength of rope and cable, what knots work best with what types of rope, how to tie every knot known to man,(I'm ex-Navy, and it has knots I didn't know!!)
It tells you how to Identify resistors by color code, It Identifies all the major chemicals you may come into contact with, safe exposures, what to do if you've been exposed to these chemicals...
This is only a small list of the info in this book!!! I could crash the server and still not list all the info this book provides!! This book is Pocket sized, but unless yo have perfect eyesight, you may need a magnifying glass.
This book also has a Companion called "Handyman in your Pocket" that has an equal amount of info, but is more geared towards home repair/ improvement.
With this book, someone whose never seen a hammer could build a house!!
These books are available through Sequoia Publishing.
Brake Fluid and Clorox makes lots of smoke!!
Note to self:
Do Not eat pink insulation.
It's NOT Cotton Candy!!
1988 F-250 4x2 5-speed 7.3 IDI
Building a www.Tremormuv.com Check it out!!!
