Go Back   Diesel Forum - The Diesel Stop.com > General Discussion > News, Comments, and Suggestions
News, Comments, and Suggestions Discussion of TheDieselStop.Com itself. What do you like or don't like, kudos and complaints, comments and suggestions.
Old 08-28-2007, 06:52 PM   #1 (permalink)
My Photos: (14)
New Look Question
With the new look I seem to have lost the "feature" that shows the messages that I've already looked at. In the past, new forum threads would be in bold (I think, anyway) and once it's been looked at, it would "un-bold." Now, everything is "un-bold" and I can't tell what I've looked at before - or what's new or old.
Also when folowing a paticular thread, if I click on it to read a new post - if there is one, I can't tell now - I'm always taken to the first original post, not the newest.
Does any of this make any sense? Is there a button that I hit wrong or need to push again?
Thanks in advance,
Jon in American Fork and LAX
2002 F-250 Lariat 4X4 Auto PSD CC SRW. Banks 4" Monster Exh, aFe Stage II w/PG 7, TAG II + Hi-Perf Comp Wheel, X-Monitor, SCMT 1705, fuel tank and pre-pump mods, harpooned tank, Zoodad air, always bright overhead, SUV-Lights harness + silverstars + SteveRacer mod, fuel regulator shim, HX oil hose, 2003 Lighted Mirrors, 203* T Stat, Rancho 9000s, C-Btr Mirrors, Roll-N-Lock bed cover, Brakesmart and Titan V. 6.0 Tranny Cooler
My Pictures
JonH is offline
Old 08-28-2007, 06:55 PM   #2 (permalink)
My Photos: (14)
Re: New Look Question
To be more accurate and specific, it's the "Replies Views" portion that used to be bold, or unbold once looked at. Now all mine are always un bold.
My Pictures
JonH is offline
Old 08-28-2007, 07:09 PM   #3 (permalink)
teamroper60's Avatar
If there are new replies to a thread, this version will put a little red number beside the number of replies.
Of course, if you are not logged in or have your settings to not allow cookies, then you will not see the red number. I would check those settings if I were you.
2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03, (still running the original flash!), AIC, MBRP turbo-back exhaust, Tuning by Total Diesel Performance, AFE PG7, Fumoto valve, B&W hitch, Di-Pricol gauges, Voyager brake controller, DIESELSITE Coolant filter, Timbrens, Rancho RSXs, Michelin XPS Traction's, a whole bunch of "bling", Connex 4300hp, JL Audio 275w amp w/ 12" sub, Alpine door and rear seat speakers. 376hp
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 08-28-2007, 08:08 PM   #4 (permalink)
BlueMule's Avatar
My Photos: (12)
Chuck
When I go into my messages I can find all the ones I received but not the ones I sent. Are they gone or am I looking in the wrong spot?
Oh, and if you remove the quotes from the "red" and "tan" in your signature the colors will work again.
2003 <span style="color: red">Toreador Red</span>/<span style="color: tan">Arizona Beige</span> CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03, (still running the original flash!), AIC, MBRP turbo-back exhaust, Edge Juice, Trans tuning by Innovative Diesel, AFE PG7, Amsoil oil & Diff fluid, Fumoto valve, B&W hitch, Di-Pricol gauges, Voyager brake controller, Timbrens, Rancho RSXs, Michelin XPS Traction's, a whole bunch of "bling", Connex 4300hp, JL Audio 275w amp w/ 12" sub, Alpine door and rear seat speakers.
BlueMule is offline
Old 08-28-2007, 08:32 PM   #5 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: BlueMule</div><div class="ubbcode-body">Chuck
2003 <span style="color: red">Toreador Red</span>/<span style="color: tan">Arizona Beige</span> CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03, (still running the original flash!), AIC, MBRP turbo-back exhaust, Edge Juice, Trans tuning by Innovative Diesel, AFE PG7, Amsoil oil & Diff fluid, Fumoto valve, B&W hitch, Di-Pricol gauges, Voyager brake controller, Timbrens, Rancho RSXs, Michelin XPS Traction's, a whole bunch of "bling", Connex 4300hp, JL Audio 275w amp w/ 12" sub, Alpine door and rear seat speakers. </div></div>
The messages you sent are there, they are just intermixed with the ones you received. I don't see a way to separate them as of yet. [img]/forums/images/%%GRAEMLIN_URL%%/frown.gif[/img]
If you look through those messages, you will find them but I have to admit, the way it's done is confusing. On the plus side, I don't think future PMs will be that confusing. I have had a few PMs since the changeover and the original PM as well as any followup replies by either myself or the other party are shown in the same PM as a string just like in the forum....
BTW, thanks for the heads up.. I hadn't even noticed the glitch in my sig.
pics
#43
Old 08-29-2007, 10:30 AM   #6 (permalink)
My Photos: (14)
Thanks Roper. I adjusted my cookies and I now see the little numbers so I can tell what threads have new entries. My little numbers are still black, but at least I can tell what's going on now.
My Pictures
JonH is offline
Old 08-29-2007, 12:07 PM   #7 (permalink)
FamilyRide's Avatar
Ya, the red (3) number of new replies is good to have, but not near as easy to see quickly if they were bold, or the topic was bold as well.
I'm still getting used to it and that seems to be the one thing that's tough t get used to. It's more work looking to see what/if there are new replies.
I've also seen, early on, where many switch to read, even using cookie crumbs to get back to the top. Although it seems like not read are starting that way until I actually read them now. But you don't know if something got marked if you didn't know it was there. [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 08-29-2007, 06:31 PM   #8 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">Ya, the red (3) number of new replies is good to have, but not near as easy to see quickly if they were bold, or the topic was bold as well.</div></div>
I agree. The bold topic indicators used to be a quick and simple way of identifying threads with new posts. Now, it all looks the same, except for the smallish red post indicators.
Personally, I think it adds to the "cluttered" look of the new layout, but that's just my $0.02.
Diesel Jay is offline
Old 08-29-2007, 06:39 PM   #9 (permalink)
Just gotta get used to it. Looks like Jason and Crew are tweaking it a little everyday. Lots better now than Sunday.
So are the birthday notifications gone for good?
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
Old 08-29-2007, 09:10 PM   #10 (permalink)
JLester's Avatar
The bold should be back now.
Jason
JLester is offline
Old 08-29-2007, 09:19 PM   #11 (permalink)
It is....I was wondering what happened....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
racerxautomotive.com
action4478 is offline
Old 08-29-2007, 10:50 PM   #12 (permalink)
Texrob1's Avatar
Send a message via Yahoo to Texrob1
Good, with the Bold back it's much easier to see! Thanks.
2005 F250 XLT wedgewood blue 4x4 C/C SWB,6.0L PSD, Auto.(Member of 05 STC Failure Club ) 2006 Expedition Eddie Bauer,5.4L (Wife's) NRA Life Member. TSRA Life member.
Texrob1 is online now
Old 08-29-2007, 10:57 PM   #13 (permalink)
x2
2000 F250 7.3, AFE stage 2, 4" custom straight pipe, shift kit, DS Predator tuner, IC foil MIA, CCV mod, ATS compressor housing, hood insulation MIA, DIY boost gauge and over boost eliminator, 195,000 miles and counting.
redfishman17 is offline
Old 08-30-2007, 12:51 AM   #14 (permalink)
Cool_Canuck's Avatar
My Photos: (12)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JLester</div><div class="ubbcode-body">The bold should be back now.
Jason
</div></div>
I'm getting to like it.
Here is most of what you need to know on getting your 7.3L started and how to operate it in the cold winter months. These posts use to readily available, but they've been hid in a subforum top of the 7.3 Power Stroke Engine and Drivetrain forum.
Winter Operation (How I Do It)
Hard/No Start? Check here first
2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/trimmed Snorkel; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED; Auto Magic Heater Bypass; 2W Low Switch.
Cool_Canuck is offline
Old 08-30-2007, 11:56 AM   #15 (permalink)
Thanks Jason, that's much easier on the eyes (at least, to mine) than every thread topic being bolded.
- Jay
