Jack,
I moved that thread to General Questions (should be a pointer to it in 7.3L E&D) since it wasn't engine related. Maybe you were posting during the move. I'll go take a look and see what's up.
on edit: Your first post was in reply to LarryP's first thread in General Questions, later, you were looking at his second thread on the same subject that I moved to General Guestions, so the problem was LarryP's CROSS-POSTING.
All fixed now.
Kevin
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version
), AIS,
coolant filter w/"hokum" bracket, regulated return,
heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
