I have a problem reading the forums from my home computer. When i click on the forum tab it does not open the forum topics. It seems like it is looking for them most often timing out. Occasionally the topics come up but then when i logon it does the same thing. Also sometimes when the topic / logon page comes up it only shows text, any type of graphic is a little box with a red "x" in it. I have tried e-mailing , but know one ever responds. I have no problem using the forum from my work computer. please give me any ideas you have.
88 f-350 4x4 crewcab 7.3L, Hypermax turbo, 4" straight pipe,5spd trans,4.11 gears ), no soup bowl,k&n air filter, .410,000 kms., 2" body lift , Luk single mass flywheel.
What version of Internet Explorer are you using? Try running I.E.6 with the updates, that may resolve your issues, also run, the Windows updates for your version, especially security patches. The Network people at your work probably take care of these issues for you at night during system maintenance, we call it a 'push'.
jerry
'91 F350 CC,7.3NA w/K&N,E40D(rebuilt--way too many times), 2WD,3.55 rear end,new IP,new u-joints & carrier bearing, new rotors, new calipers, new drums & hdware, added Auburn limited slip unit (2/8/05)w/valvoline synth 80-90w, new batt.cables,new window motors,new radiator & hoses, 500K, (new injectors)+ mi (now 678K miles)& still Truck'n. If I can fix it, it ain't broke, I'd rather do it myself.(yes, I add,stanadyne, lucas or power sytems fuel additive in every tank, w/maybe 1-2x year full big bottle dose split between both tanks). New tires & pretty wheels, front end rebuild 3/17/05. Bilsteins added 6/12/05. New motor mounts & valve cover gaskets (9/06.)Future hopes finally fixing my electric door locks & adding remote entry/alarm system. http://community.webshots.com/user/jl_mendoza
Well, unfortunately I am out of suggestions. Other than a DNS or cache problem, I don't know of anything else that could be causing it. Are any other sites behaving this way?
I have experienced the problem you have been having on other site but not TDS.com
SP
__________________ The Diesel Stop FAQ Editor
"I'm Not Dead."
- Old Guy, Monty Python and The Holy Grail
none this the only one. I will call my service provider to see if they can help. Thay have always been pretty good in the past helping out even if it's not related to the internet. Thanks for your help.
