It must be just yours. I can go to page 12 of the "N" list just fine. The only thing I see wierd is the avatar of 97F250HD is not there, but maybe if I waited longer it would show up?
Smokey, is that difficulty in finding your entry in the user list the reason why you posted 25k times? [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
Jim
2005 F250 PSD 4x4 CC LB KR
fully loaded, Snugtop Expo, PIE, Van Aaken Smartbox F pictures
Still some 24k posts left for me. [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img] Away from that is it possible to search for e.g. "jim*"?
Jim
no however, when you click a letter, for example "J" at the top, when the first page loads of just "J" names, look at the address bar, in the address, you will see somthing along the lines of "Cat=0&like=j&sb=1&page=1" at the end of the address, if you change it to "Cat=0&like=Jim&sb=1&page=1" you will see any names starting with jim.
This process has been invalueable to me since the search restrictions have been put in place. it makes navigating the user list near impossible.
2000 F-350 NVK5, XLT Island Blue 7.3 PSD 3:73LS Reg Cab LB, STOCK EXCEPT:BTS Transmission,Ummmm... Injectors, Home made HUGE Tymar,TC-Lock Mod, CCV mod, Heater-plug mod,6-Pos "Chip", Autometer Z-Series/ISSPro Gauge pod,407hp/849.1FtLbs WEBMASTER Western New York Powerstroke Assoc. http://WWW.WNYPA.ORG NOT A GIRLY MAN'S TRUCK!!!
XLT Carpet Delete
no however, when you click a letter, for example "J" at the top, when the first page loads of just "J" names, look at the address bar, in the address, you will see somthing along the lines of "Cat=0&like=j&sb=1&page=1" at the end of the address, if you change it to "Cat=0&like=Jimj&sb=1&page=1" you will see any names starting with jim.
Thanks for the tip. [img]/ubbthreads/images/graemlins/cool.gif[/img]
I've never liked the way the userlist was laid out. That sure makes it a lot easier to find a username that I can't quite remember.
Your example and solution searches for usernames beginning with jimj not jim. You have an extra j in the example URL. Probably a typo in your example. To get usernames that start with jim, that's all you need.
Another way to move further along in the list beyond the page numbers listed at the bottom is to just change the page=1 to say page=68. That will step you ahead beyond what page numbers are listed at the bottom. If your number entered is more than what pages there are, it defaults to the last page whatever that may be.
__________________ TheDieselStop.Com Photo Editor/Moderator
May '02 F-350 7.3L SC Lariat 4x4 Auto SRW LWB, XM Satellite Radio
June '97 F-350 7.3L Reg Cab XLT 4x4 Auto SRW, CD and XM Satellite Radio
Well I decided to try it again Oct,1 and the same thing happens to me. I have aol broadband and when I go to page 12 in the " N " section it shuts down aol and then aol restarts itself. I guess my computer just does not want me to view that page. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1996 250 SC LWB 4x4, Triple Piller/w Autometer 60 PSI Boost - Pyro - EGT Gauges, BTS Trans, Rebuilt Motor 6/01/07, Swamps Large Gator Squiters, Swamps Gen 3 Custom HPOP, Sledgehammer Turbo, 99 IC conv., Headstuds, Cometic HG's, 203* Thermostat, Evans Coolant, Swamps Programing, JS IDM, Vortex Custom Fuel System, Open Air Intake, 4" Downpipe, 5" Miter Cut Stacks, Custom CCV Mod, Homemade Oil Bypass, Dana 60 Axle Swap, Custom RSK w/2001 springs, New paint job, Onyx Spray-In Bedliner, Kenwood Stereo, Complete Interior Overhaul
