Ok, I can quote somebody but how can I have more than one quote at a time...? [img]/ubbthreads/images/graemlins/shrug.gif[/img] You know like when they are all stacked on top of each other.
Be back in 12 hours for my answer [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
I'll turn off UBB Code/HTML to show you the actual code in this post. Then the next post I'll turn UBBCode back on to show how it looks to members viewing the coded quotes:
Ok, I can quote somebody ...
That's one quote.
...but how can I have more than one quote at a time...?
That's the second quote. See how easy it is to code?
You mean like this?
It'll be here waiting for you when you get back.
:warmsmile:
I'll turn off UBB Code/HTML to show you the actual code in this post. Then the next post I'll turn UBBCode to show how it looks to members viewing the coded quotes:
That's one quote.
Quote 2: reply to quote 1 with original post{/quote}
Quote 3: reply to quote 2 with original post and quote 1{/quote}
and so on or like the above which I think the S/W does it now [img]/ubbthreads/images/graemlins/grin.gif[/img]
The way that is done is to put the number of nested {quote} brackets first and then a {/quote} after each threaded reply but using the [] vs the {} in the actual post. In the above there were 4 {quote} and 4 {/quote} and have included the actual code using the {} vs the [] in the text above including the locations of each in the actual text.
Larry
__________________ <font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Quote 2: reply to quote 1 with original post{/quote]
Larry
you should turn off the UBB code like smokey did so he can understand what the nested quotes will look like on his little post screen.
