All in all I think I am navagating everything well. One request tho. If there was a thread that had 13 posts and I had read 6 of them when I opened it for the second time it would jump to the most current response. This is no longer happening. Can it again?
I have seen some questions about old private messages. Are they going to come back?
Mark if you look for the small blue arrow just below the time of last post and click on it it takes you to last post
Jim Sult / Excavator (we dig it) Trying to fix it? KISS IT"KEEP IT SIMPLE STUPID"
Avatar- my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Stock for now Auto trans, BabySwamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 173000 miles
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, Tymar intake, 112000 miles
As the Italian Mom said about the pizza sauce, "It's in there!"
When you look at the forum index, the threads with new posts will have a green checkmark on the left side of the topic title. If you click on the topic title, you will go to the first post in the thread.
However, if you click on that little check mark, you will go to the first new post in the thread. (Put your cursor over that check mark and read the popup.)
No, probably not. The admins are still pondering and scratching their heads, but the last word was that they can't figure out a way to get to transfer over to the new software. However, they have posted a link so you can now go back to the old website - temporarily - and do whatever you like with your old PMs.
Check out the stickie at the top of this forum.
Arrows work great. I have trimmed my old PM's down to the min so I will try and get those this weekend.
