Go Back   Diesel Forum - The Diesel Stop.com > General Discussion > News, Comments, and Suggestions
News, Comments, and Suggestions Discussion of TheDieselStop.Com itself. What do you like or don't like, kudos and complaints, comments and suggestions.
Old 10-30-2004, 01:44 AM   #1 (permalink)
Search engine needs help!
I like to look for old posts to learn as much as possible, but would like to be able to search by topic. It often doesn't work. Can it be fixed?
If you don't have anything to do, get a used diesel and a camper!
Truck 1: 1985 F350 dually 4WD 6.9 diesel crew cab auto with 83k original miles. C6 trans, 4.10 rear end. Mods are Banks Turbo, US Gear overdrive, 45gal rear tank, hydroboost brakes, additional leaf springs all around, Hellwig airbags, rear sway bar, GM glowplug controller, fuel Koalescer. 235/85 R16 Michelin XB Rib radials. 11ft.6in Vacationeer cabover camper, TorkLift tiedowns.
Truck 2: 1988 F250 7.3, C6 auto, 2WD w/3.55 limited slip rear axle, Banks Sidewinder Turbo, Gear Vendors overdrive, Utility box, hydraulic lift gate, lumber rack.
Auto: 1987 MBZ 300D Turbo 3.0 Liter 6 cylinder engine. 205K miles. Working on all the "little things" that previous owner neglected. Putting in wvo tank.
Monte1 is offline
Old 10-30-2004, 08:26 AM   #2 (permalink)
My Photos: (11)
Re: Search engine needs help!
The search engines as far as I know are what they are and are part of the current forum S/W that TDS uses. Features can be turned on or off, but any problems have to be fixed by the S/W providers.
As far as searching for topics, I'm not sure what you mean when you say it "doesn't work". Many times words are mispelled or topics aren't readily apparant in their titles, but you just have to work with what is here.
If you can give a specific example and show how it didn't work we can talk about that, but I think in this case we'll never get a 100% search feature. I've used it probably more than most members here, and found it very efficient.
I know this isn't a very good answer, but it's my take on the search feature. For a start you might check out the "little secrets" which again are far from perfect, but they're free and are arranged by topic. Of course my cataloging of the topics is my own and others would have done it differently.
Larry, keeper of the <font color="blue">"little secrets" </font> CLICK HERE [img]/ubbthreads/images/graemlins/smile.gif[/img]
<font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Larry M is offline
Old 10-30-2004, 07:21 PM   #3 (permalink)
i too am getting frustrated with the search feature....if it worked better, there would be a lot less repeat threads.
specific examples include
heated seats
led
edge mini spring pack
...the list goes on
any more specific and it doesnt show any results...with it this broad it shows threads that people list heated seats in their sig, even with it just set to search topic, not body
Ford Truck Enthusiest!
FOR SALE! 2003 F-350 lariat crew cab long box.
My Vehicles
justinthurn is offline
Old 10-30-2004, 07:41 PM   #4 (permalink)
My Photos: (11)
heated seats
led
...the list goes on
Since you've provided some specific examples here is what I would ahve done on your examples.
1. heated seats ... do a "+heated +seats" (the + are important here for searching) and done it in the U&amp;A - general and "General Questions" forums. This should have worked great and I would like to hear why you didn't think this worked for what you wanted. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2. LED .... useless IMO unless your comibne it with the "+" advanced option and narrow it down some. Single word searchs are IMO worthless as are much above three. I've found that two are ideal.
3. edge mini sping pack .... too many words the best it to only use "two words" that describe what you're looking for. Also, not nitpicking but "sping" is not "spring" and can cause all kinds of problems.
Point being as in my previous post it takes some time and working to get the search feature to work for you right, but IMO it works really good once you work "WITH IT" instead of "FIGHTING IT". [img]/ubbthreads/images/graemlins/wink.gif[/img]
Larry M.
Moderator
Larry M is offline
Old 11-01-2004, 12:20 AM   #5 (permalink)
jna
i too think this search engine is absolutely brutal [img]/ubbthreads/images/graemlins/vomit.gif[/img]. man its the 90's...get a google search engine put on this sucker!! i dont know how the comp guys do it, but a site can use google method of searching for things only on thier site. i actually get more related tds posts if i use the www google search.
its like you have to know some secret code of actually getting something sort of relevant then just the weeks posts as results.
figure it out and get rid of the terrible search engine!! everyone hates it and it contributes to more repetition on posts b/c NO ONE can use the darn thing!!!
jared
1996 F-250 POWERSTROKE , Crew Cab Short Bed, 4x4
Custom Air Ride
BDP Dominator 66
Stetcher Stealth Pump
Total Diesel Chip
150cc Swamp Babies
BDP fuel system
many[color:"blue"] TYMAR mods [/color]
TRUCK
BTS
Dana 60
2008 F-450 4x4
jna is offline
Old 11-03-2004, 10:59 AM   #6 (permalink)
Larry,
I agree with the other posts. Since I'm new, I probably don't know how to make the search engine work as well as you apparently do. If there is a trick, I'd like to know it. I also find it easier to find what I'm looking for on Dieselstop.com using Google. Example:
I was looking for info on 19.5 inch wheels over the last 12 months.
I got a LOT of posts unrelated to the topic, and it individually references EVERY reply to a post. Also, once I start looking through all the pages of references, the engine seems to "forget" the original search criteria. Is there a loose screw behind my steering wheel?
Monte1 is offline
Old 11-03-2004, 03:22 PM   #7 (permalink)
My Photos: (11)
Larry,
I'm not sure what to say since I just did a search over the last year in the "U&amp;A - General" forum using the search criteria "+19.5 +wheel" and got like 75 hits and they all seemed to match the search criteria.
Now if you do a search on "19.5 wheels" you will get some funky hits since you're not searching for both items. You search for the phrase and then apparantly either or of the terms.
I always limit my search to only two words and used the "+" advanced search option.
Larry M is offline
Old 12-04-2004, 08:35 PM   #8 (permalink)
I think the people here do a terrific job with the web site, but I am also having problems with the search engine.
Things I found this morning don't show up.
For example, with google I found the "dana factory option" thread.
I tried it on this search and it didn't find anything, I tried with +dana +factory, and nothing came up either.
Same with a thread that was something like "Recommended maintenance for high mileage", I found it this morning looking for the brake fluid change thread, never found it again.
It is very weird.
But, I'll stop complaining and want to thank everybody who works for this page, you do an awesome job.
Dro
early 99 (10/98) F-350 CC LWB 6 sp 3.73; 286,000 miles. Lock-Right Dana 50, open sterling 10.5, Kelly AWR 255/85R16, 4" exhaust, cold air intake, Westach EGT-Boost gauge, EBPV Brake . Then it died, I just rebuilt engine but I now have no boost, please read my post. Any help will be welcome.
alalor1 is offline
» Sponsor Links
»Garage Storage and Cabinets
