I have not been able to use the search mode since the update. Is there anyone else having simalar problems???
05 Expedition 5.4 3 valve. (It does better in the mileage catagory on the interstate than my 6.0 EVER did!!!!)
GONE!!!!!!2003 F250 CC 4x4 <font color="red"> 6.0 PSD</font> 6 Speed, 3.73 XLT Dark Shadow Gray ,Moonroof, Camper Package, Skid plates ect. (Gutless PIG from idle to 1800) May 12th 03 build week. 122,000 miles as of 01/01/07......... 4" exhaust and AFE intake b&w turnover ball.
Flashed 6 times, EGR cooler replaced, VVRT solenoid replaced, Turbo Ped Replaced, EGR valve replaced 2X NO LEAKS!!! 8 new injectors, new fuel pump, new FICM, new ball joints, Exaust manifold gaskets, both front wheel bearing assy's, The list goes on and on!!!
Former trucks:
89 F250 2wd 7.3 5spd with 256K when sold
94 F250 4X4 IDI Turbo 7.3 5 spd 160K when sold
95 F250 S/C 4x4 PSD 5 spd with 146K when sold
00 F250 C/C 4X4 PSD 6 Spd with 126K when sold (160K now)
None of these trucks EVER spent a day in the shop!!!!
[img]images/icons/laugh.gif[/img] Works fine for me - need to give the search time to go through the extensive files if you are in the archives.
97F250,HD,4x4w/manualhubs ,XLT,SC, offroad pkg,PSD,5spd,4.10's, lmtd.slip,camper special/tow package , add a leaf, w/super duty air lifts,Amsoil air filter and gear lubes,ported snorkel,Michelin LTX M/S 265-75-16's
Read my post a few days ago, I was also having diffculty. I think it will help. Also another member was having diffculty, you might want to read his post also. [img]images/icons/tongue.gif[/img]
02 F-250 PSD SC Lariat 4X4 auto,3.73LS Long bed. 2 black roof mounted Grover air horns, spray in rhino liner.
Hi
When I use the search feature I am able to read only one search result. Trying to use the "back" button gives me an error message. I then have to restart the search to read the next result. Also since the upgrade this bb is still much slower than previously. I'm not on a dial up [img]images/icons/smile.gif[/img]
Not complaning.. you wanted details.
00 F350XLT DRW 6sp 4:10 Blk
Franklin,Tx.
etc. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Halo's problem could be browser/cache-related. After you have done your search and have a list of hits, try holding the SHIFT key when you click on one of the links. This will open a new browser window. Read the post, then exit that browser window. Your original browser window will have the list of hits. This may or may not working depending upon which browser you are using, but it might be worth a try.
Also, just another thought: some folks were saying the search function didn't work because they were getting zero hits on pretty common terms. This happened a few weeks ago around the time Jason archived the big forums. So that was probably a result of searching the relatively empty new forums. You'll need to search the archives instead until the new forums get populated.
One last thing, it is always better to search within a particular forum, not "all forums," which is very slow and often hangs the computer.
Not sure if this solves your problems, but it might solve somebody elses!
When i hit search from the main page i get to the site search page. When i click on:"Search Forums", I get this:
The page cannot be found
The page you are looking for might have been removed, had its name changed, or is temporarily unavailable.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
Open the www.ford-diesel.com home page, and then look for links to the information you want.
Click the Back button to try another link.
Click Search to look for information on the Internet.
HTTP 404 - File not found
Internet Explorer
Former trucks:
I just did a search using your member number. Everything seemed to work fine.
What browser are you using? Netscape doesn't work well at all with this new version of UBB. I was using Netscape, changed to IE 5.0 which worked fairly well, then upgraded to IE 5.5 which works great.
I am using IE 5. This is the only problem i am having. I have no idea what is going on but it worked fine before the changover.
Matt
Former trucks:
I reset all defaults and rebooted the pc and still no search!!!! What the $^&* is going on here!!
"HTTP 404 - File not found
Internet Explorer"
Former trucks:
