Re: Search limited by number of returned topics?
The search function is limited to the first 200 hits by default. It can be changed in the control panel by the administrator. However, if the limit is increased, it can start to bog the board down. You will need to search smaller segments when you search for something that will return a lot of hits. You may be able to change your search terms to be more specific and reduce the number of hits.
When you do the "older than 1 year," try also specifying "newer than 2 years."
You won't find anything older than February of 2005, because that's when it was archived.
Or, you can use Google or whatever to search TDS specifically.
Steve
2004 Ford F150 FX4 SCAB, 2005 Volvo XC90 T6, and a bunch of Crown Victorias
