Search link / Hyperlinks all the same - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > General Discussion > News, Comments, and Suggestions
News, Comments, and Suggestions Discussion of TheDieselStop.Com itself. What do you like or don't like, kudos and complaints, comments and suggestions.
Old 12-15-2008, 08:19 AM   #1 (permalink)
gnxtc2's Avatar
Problem within a thread when using the search feature. When you enter a thread from the search function and that thread has a link to another thread, all the links are linked to this: Beds and Tow Bodies for Chassis Cab Trucks
I think this happens in any searched thread.
Example:
Was in----> Power Strokes 1994-1997 Upgrades and Aftermarket
Search this forum----> Hydroboost
Results and entered this thread----> SD hydroboost scroll down to post #3 and click on any of the links
Billy T.
gnxtc2@aol.com
'97 Black F250HD,XLT, SC, LB, 4x4, Suncoast E40D, Triple Disk Converter, Dana 60, 3.55LS, built 12/97, 3"-4" DP, Bilstein 5125s, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, CA fuel regulator, 4" Exhaust-Straight piped,FORD AIC, welded EBPV, B&M Transpan, Cryo slotted rotors, Tony Wildman 4 position chip, Joe Servo IDM, MAP sensor mod, Blackbird rear disc conversion, RSK w/ "V" & "F" code SD springs, Hydroboost conversion, replacement 38 gal rear tank, Swamp's Baby Hybrids, CJC Traction blocks, 209K <---STOLEN
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 12-15-2008, 03:53 PM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Caused by clicking on an old link that was posted under the old forums software = UBBThreads.
We transitioned to VBulletin forums software about a year ago, so any older links have to be converted before they will work right.
For example, if you right-click on that link, then click on "properties", then look at the URL you will see:
url =http: // forums. thedieselstop.com/ ubbthreads/showflat. php?Cat=0&amp;Board=9497upgrades1&amp;Number= 2941345&amp;Searchpage=1&amp;Main =2940258&amp;Words= hydroboost&amp;topic=&amp;Search= true#Post2941345
But without the spaces I added to prevent it from becoming a link.
Notice early in the URL is the folder "/ubbthreads/". But that's an invalid folder now.
I don't remember how to correct the URL to convert that ubbthreads to something that will work, but other moderators probably remember. Hang on and one of them will probably give you the straight scoop.
SmokeyWren is offline
