How can I search for a users pics? I believe there use to be a choice to search by username or description. There was two dot boxes.
Any suggestions?
Thank you,
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
If the member has a link to his pictures in his sig, then find any post by that member.
To search by username, first you must know how to spell the username - exactly.
Then click on the search button and notice 4 small windows.
[*] Forum or Catogory: Pick one that you think the member has posted in - don't let it default.
[*] Words: Enter the username you're searching for. Spelled exactly right, including case of the letters.
[*] Search options: click on that one and then click on "By Username"
[*] Date Range: Pick one. The default is probably too low to find anyone, so change it to one month or more.
Works for me.
Well that kinda helps. Thanks but the user doesn't have links to pics in the sig.
Photo page.
If you go here (above), on the right there is the box for searching. I swear there was use to be the option of searching by user or description.
How do I do a search in the photo gallery only?
Thanks again.
I kinda found a way around it. For searching by a users name. Try this. Here the search box is empty, if you type soaggydogg it comes up with nothing.
If you go here the search box has psdnut (his username) in the search box. Now try and type soaggydogg and you get my photos.
To get the username in the search box you must click on photo, then click on the (see all of username's photos). Then it works.
This is a round about way to do it, but it works. At least until our search button comes back.
