Re: thru the valve cover connectors
Welcome to the site. This item has been discussed in the 94-97 forum and you should be able to find some info by doing a search. I don't remember the details but I beleive one poster replaced the connectors with another type but the best alternative was to get the undercover harness from Navistar/International.
95 F-250 SC, 4x4, E4OD, 4.10, Tweaks by Hypermax, Xcelerator filter, Front add-a-leaf, Firestone Ride Rite, Hellwig rear sway bar, KYBs, Milemarker hubs, EGT and Boost gauges, Turbo-Trac, Century topper and 24 ft Nomad Fifth w/slide. If you don't care where you are, you ain't lost.
Larry
97 F-250 SC LB PSD. 4x4, BTS E4OD, 4:10LS. Baby Swamps, DP-Tuner F5 custom 6 program chip, 1.0 housing, SD-IC, SD-HPOP, IDM mod, HPX, Black Box ICP mod, Black Box MAP sim mod, Hypermax DP & 5" ex., Aero-Turbine, TYMAR intake, RW Turbo-Trac, Gauges, Airlift bags, Add-a-leaf, Superwinch hubs, Class V rear receiver, RBW Lil Rocker, DIY Tow hooks. Milemarker hyd. winch. Elkhorn 9VS slide-in, Nomad 24 ft. fifth/w slide, Century topper, old classic Sooner 18' 4 horse stock trailer. StarFlyte by DynaMax 6.8 V10
Larry
