Go Back   Diesel Forum - The Diesel Stop.com > General Discussion > News, Comments, and Suggestions
News, Comments, and Suggestions Discussion of TheDieselStop.Com itself. What do you like or don't like, kudos and complaints, comments and suggestions.
Old 04-30-2006, 03:43 PM   #1 (permalink)
My Photos: (5)
we need a tranny forum
does this not make sense? My tranny thread just got moved to a section where very few look. It seems the trans questions are everywhere and it is impossible to keep up with the stuff. My 2 cents.
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
Old 04-30-2006, 04:01 PM   #2 (permalink)
Re: we need a tranny forum
A tranny forum sounds like a good idea. Good technical knowledge to interest members of TDS. The thought can quickly be shot down in flames.
Good suggestion though. I hope it is taken into consideration.
"Real Trucks Don't Have Spark Plugs"
2000 F250 Lariat Crew Cab, Island Blue/ Harvest Gold , 7.3 PSD, LWB, 4x4 ESOF, Auto Trans. 3.73LS, 285/75/16,AT/BFG, Husky Liner Floor Mats, AIS/Foam Fender Sleeve Mod. Line-X, Leer 100XL Cap, MOOG Balljoints, Performance Friction Rotors and Z Rated Carbon Metallic Pads, Fumoto Valve, DIPricol Optix Gauges, Pyro,Trans,Boost, A-pillar Pod, MBRP 4 inch T-304 SS Cool Duals, EBPV delete 6.0L Trans. Cooler,Schaffer's Transmission Fluid, BTS Transmission, DP Tunes, Stock/High Idle/40T/60T/80E/120R/140SMK 309.77 hp/605.12tq
Spooling and Cooling by BWD with a Turbonetics Turbo & Spearco Big 6.0 IC
"The Smoke Don't Mean Its Broke!"
Bushwakd is offline
Old 04-30-2006, 04:10 PM   #3 (permalink)
I agree [img]/ubbthreads/images/graemlins/smile.gif[/img]. I am a constant reader, rare poster and have spent $$ with several sponsors. I have been a member for a couple of years and have found tranny research a little frustrating. Granted you can have too many forums, but when I have had tranny questions I have had to do multiple searches in multiple forums. Even though I am fairly adept at using +/- and other terms it was still tedious. I see others posting tranny/clutch questions all over the place; sometimes they get moved sometimes not. If there was a tranny forum even newbies would know to post their questions there and look there. I seldom read "general diesel" unless the latest topic that shows up in the forums list catches my eye. Have to say though that NO user group can be all things to all people. This is a great forum and my thanks to those that make it happen.
Best Regards,
Jeff
2001 Excursion 4wd PSD Limited White. V's B's 03 bump stops- Hellwig rear antisway, RAS. Straight Pipe - AIS - Bilsteins- Magnefine trans filter - coolant filter, Cooper 285 ATRs (amazing good tires,and a bunch of other stuff. "Thanks Bruce1954". Took delivery with 124 mi. now has 112k - since warranty ran out had to replace water pump & Left Front Hub Everything else works fine. Well-- I wish the stereo was better.
kd5fyx is offline
Old 04-30-2006, 06:51 PM   #4 (permalink)
klhansen's Avatar
My Photos: (92)
A tranny forum would be nice. Maybe we could add a wheel and tire forum. How about paint, or maybe even windshield wipers? [img]/ubbthreads/images/graemlins/wink.gif[/img]
I just checked both the U&A-General Forum and the U&A-7.3L Engine Forum. U&A general had 15 total viewing, while U&A 7.3L had 33 total viewing. So even though it's not quite half the number of viewers I don't think that qualifies as "very few".
It never hurts to broaden one's horizons. You may focus on tranny's, but there's lots more than that here on TDS.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 04-30-2006, 07:05 PM   #5 (permalink)
My Photos: (5)
My horizons are broad, I do everything on these trucks, not just trannies.
1999.5 cc dually
Old 05-01-2006, 06:16 PM   #6 (permalink)
My Photos: (11)
I'm not sure about a separate tranny forum, but I do think the layout for the 99+ SDs is getting confusing and if the new 6.4L engine is added in there things will only get more confusing.
It's sort of confusing now in the T&H forums since GCWR varies a lot and things like mpg and towing characteristics vary between all the like 6 or so different models - engine/drivetrain setups.
I think having some common forums (such as the Gen Q's and Gen U&A in the current 99+ section) that are applicable to different drivetrain or even significant model years might not be such a hot idea. You two threads here sort of point this out [img]/ubbthreads/images/graemlins/cool.gif[/img]
It seems the last significant change when the 94-97 forum was split out got a positive review and maybe something along that take should be looked at for all models except maybe for the E-series, 7.3L IDI, 6.9L, and Gas Engine forums.
Larry
<font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Larry M is offline
Old 05-01-2006, 11:45 PM   #7 (permalink)
My Photos: (5)
you can take the total of all the posts in the towing and bio forums plus one or two others and all the tranny posts scattered throughout the site would still top it.
1999.5 cc dually
Old 05-02-2006, 02:16 AM   #8 (permalink)
We need a trany forum. Support Richter69 in his quest to help us all.
2000 F250SD 4x4 CC LB SRW, 7.3L, 4" SS Exhaust, K&N Intake Filter, "A" pilar guages, Autometer Trans Temp, EGT, Boost, Amsoil through out, Amsoil 2 stage filter system, Mag-Hytec trans pan & dif cover, Banks Big Head Waste Gate, FactoryTech Valve Body, 315 BFG KOs & Yes I made the 315 spare fit, Rancho 9000 shocks, Tru-Cool Max trans cooler, Aux/BU Lights, T/C lock. Next: Fuel System Mods, Max A/C mod.
1975 TLC 2F, H42, 4.88 gears, Power Steering, Shackle Revearsal, Next: SOA, Rear Disc Brake mods
A Scouter Forever.
Bigguy6907 is offline
Old 05-02-2006, 08:36 AM   #9 (permalink)
SmokeyWren's Avatar
My Photos: (33)
There will never be enough forums to satisfy everybody.
If we had a tranny forum, it would be confusing to have the TorqueShift, 4R100, E40D, 5-speed ZF, and 6-speed ZF trannies all in the same forum. So then we'd need 5 forums just for the trannies. Then we'd probably need an upgrades and aftermarket forum for at least the 6-speed manual guys to discuss their LUK clutches, and for the 4R100 guys to brag about their Brian's Truck Shop (BTS) rebuild, etc. So that's 10 new forums?
Where does it end?
I know that if I want to read about my 4R100 tranny, it's probably going to be in the '99-up 7.3L Engine and Drivetrain Forum. Maybe in the '99-up 7.3L Upgrades and Aftermarket forum for the good stuff such as a BTS bulletproofing.
So I don't agree that we need more forums until the 6.0L engine is replaced by something different.
SmokeyWren is online now
Old 05-02-2006, 10:48 AM   #10 (permalink)
Well what we really need is a tranny FAQ.
The same questions come up every few days in the IDI forums on the E4OD / 4R100. It starts with "my trans is acting up" and finishes with "how much is a new trans". 9 times out of 10 it's just a bad sensor out of a handful of sensors. The ones that post are the lucky ones, there are many more than drop in a new trans, only to have the same problems so they just keep driving and ruin a new trans.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 05-02-2006, 10:44 PM   #11 (permalink)
teamroper60's Avatar
I have just removed several posts that had resorted to nothing more than bashing. This one is done.
2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03, (still running the original flash!), AIC, MBRP turbo-back exhaust, Tuning by Total Diesel Performance, AFE PG7, Fumoto valve, B&W hitch, Di-Pricol gauges, Voyager brake controller, DIESELSITE Coolant filter, Timbrens, Rancho RSXs, Michelin XPS Traction's, a whole bunch of "bling", Connex 4300hp, JL Audio 275w amp w/ 12" sub, Alpine door and rear seat speakers. 376hp
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
