Go Back   Diesel Forum - The Diesel Stop.com > General Discussion > News, Comments, and Suggestions
News, Comments, and Suggestions Discussion of TheDieselStop.Com itself. What do you like or don't like, kudos and complaints, comments and suggestions.
Old 08-28-2008, 11:59 PM   #1 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
What happened to the Quick Reply?
Is it just me, or have they gotten rid of the Quick Reply at the bottom of the threads? I can deal with it not being there, but it was convienient. Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 08-29-2008, 06:18 AM   #2 (permalink)
RDG
RDG's Avatar
My Photos: (15)
It's still there. Look at the bottom where it says EDIT QUOTE then there are two ICONS. The one on the far right is the quick reply button.
Bob
Retired: UAW 383 12.01.03 after 32 years at BENDIX, Allied, AlliedSignal, BOSCH, St Joseph MI Plant
99.5 F-250 CC SRW: Automatic, 3:73 Gears, Tymar Intake, SpeedLiner Bed Coating, Timbren Rubber Springs, Hayden Trans Cooler, Perma Cool Trans Filter, Sonnax Valve & Tricumulator Springs, Reese 15,000lb 5th Wheel Hitch, Tekonsha Prodigy Trailer Brake Controller, Handy Flow Thru T-gate, AFE 4" Exhaust, Warn Hubs, SP Diesel EB, GOS Headlight Harness, Smoked Headlights & Corners with Sylvania Silverstar ULTRA SU bulbs, 08 Sterling Alum Diff Cover, Delphi XM Radio, TomTom One XL-S GPS with ProClip mount
DIESELSITE Stuff: Super Chip 1705 Programmer, AutoMeter Lunar Gauges In Under The Cubby Hole Mount, AC Control Valve, AIH Plug, Coolant filter, Wicked Wheel, BilletTstat Housing, 203 degree Tstat & HX cross over hose..
RDG is offline
Old 08-29-2008, 07:54 AM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (33)
That quick reply icon does nothing more than move you to the bottom of the current screen, where the quick reply area is still there.
SmokeyWren is online now
Old 08-29-2008, 08:48 AM   #4 (permalink)
Dick Cutting's Avatar
My Photos: (18)
Originally Posted by RDG View Post
Look at the bottom where it says EDIT QUOTE then there are two ICONS. The one on the far left is the quick reply button.
Bob
The Quick Reply button/icon is at the far RIGHT.
That row of icons from Left to Right are: "EDIT" , "QUOTE", "Multi Quote this Message", and "Quick reply to this message"
TheDieselStop.Com Photo Editor/Moderator
May '02 F-350 7.3L SC Lariat 4x4 Auto SRW LWB, XM Satellite Radio
June '97 F-350 7.3L Reg Cab XLT 4x4 Auto SRW, CD and XM Satellite Radio
Dick Cutting is offline
Old 08-29-2008, 09:45 AM   #5 (permalink)
RDG
RDG's Avatar
My Photos: (15)
Yep. on the RIGHT side.
RDG is offline
Old 08-29-2008, 03:09 PM   #6 (permalink)
RatherBNtheWoods's Avatar
Doesn't work for me. When I click the right most icon, with the little arrow in it, nothing happens. And the bottom of the page doesn't have the quick reply like it used to.
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 100gal aux fuel tank. A real pig from a stop, but give me 10' and she'll lite'em up.
RatherBNtheWoods is offline
Old 08-29-2008, 03:39 PM   #7 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Browser? I'm using Windows Vista and the IE that came with it, and it works fine.
Old 08-29-2008, 03:48 PM   #8 (permalink)
BlueMule's Avatar
My Photos: (12)
It doesn't work for me either. The icon is there but it does nothing and there is no reply area at the bottom like there used to be.
And what happened to the "jump to" button that used to be at the bottom? It's gone also.
BlueMule is offline
Old 08-29-2008, 04:32 PM   #9 (permalink)
chuckster57's Avatar
me either
the quick reply doesn't work, and while I am at it, the "search" button does not work, nor does the clicking on a member and getting the drop down menu. I am running Windows Vista and IE7
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually,
1997 Jayco fifth wheel 323 RKS, Robins 16K dual axis hitch
Apillar pod with: Autometer C2 Series gauges: pyro,trans, boost
Hypermax Cowl induction, Flex-A-Lite 26K tranny cooler w/fan
K&N air filter (we'll see in a million miles)
Tekonsha "prodigy" brake control
Train Horns: Pictures here
chuckster57 is offline
Old 08-29-2008, 04:38 PM   #10 (permalink)
Search and the other pull downs seem to work if I'm not viewing a thread.
Like say form the main forums page, I can search but once in a thread I can't.
Our Raptor RV
Old 08-29-2008, 04:39 PM   #11 (permalink)
Whoa!!! A soon as I posted that last post, it all started working. Search works and there's a quick post section at the bottom!!
Our Raptor RV
Old 08-29-2008, 04:42 PM   #12 (permalink)
search only work for me if I am replying to a thread.
Old 08-29-2008, 04:46 PM   #13 (permalink)
Supporting Member
bugman's Avatar
My Photos: (15)
Everything is working for me. Just a question on those that don't see the quick reply is do you have it colapsed? If I colapse mine all I see in that area is a title "Quick Reply"
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
bugman is online now
Old 08-29-2008, 04:51 PM   #14 (permalink)
Jim
I haven't changed any settings and it all worked yesterday. I cannot search at any point other than if I am replying. If I click on a member in a thread it used to give me the drop down menu for viewing public profile, gone now. Quick links is the same..no worky unless in "reply" mode.
Old 08-29-2008, 08:02 PM   #15 (permalink)
My Photos: (18)
Well, its back today. I don't know why it wouldn't work yesterday (???). I would scroll all the way to the bottom and I would only get the ad just above the quick reply. It was working before then because I would go to quick reply and I would encounter the stupid "expanding ad windows" (very very annoying) when rolling over it. I haven't changed a thing, settings wise. Cheers!
