Go Back   Diesel Forum - The Diesel Stop.com > General Discussion > News, Comments, and Suggestions
News, Comments, and Suggestions Discussion of TheDieselStop.Com itself. What do you like or don't like, kudos and complaints, comments and suggestions.
Old 01-06-2006, 09:47 PM   #1 (permalink)
Where is support around here?
I've been locked out of here for over a week and emails to support go unanswered. I finally signed on under another user name just so the sites cookies will remember what I've read.
How frustrating.
Happy New Year!
Dan
1987 Ford F-350 FWD 4spd. 6.9L Forestry body.
1983 Ford F600 Allison 545 Auto 8.3L Detroit Diesel w/15ft. Chipper box.
1985 International S1900 DT466 5spd 2spd rear
1996 Dodge 3/4 Ton 4WD extended cab 5.9L Cummins Auto Trans.
Two stump grinders with 58/75hp. Duetz diesels.
Bandit chipper w/116hp. Cummins 4BTA diesel.
Bobcat 7753 with 46hp Kubota
TreeCo is offline
Old 01-06-2006, 11:26 PM   #2 (permalink)
Re: Where is support around here?
That sucks Dan. I had that happen to me over at another diesel site, and also a friend of mine had it happen here. My best suggestion is to talk to one of teh moderators. It might be a problem with your browser or cookies or something.
J.D.
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
Old 01-06-2006, 11:47 PM   #3 (permalink)
I was locked out a year ago for no real reason. All I needed to know was to go to the news and comments section for help getting back loged on.
icanfixall is offline
Old 01-07-2006, 09:40 AM   #4 (permalink)
Dick Cutting's Avatar
My Photos: (18)
Check you e-mail. The old account is still exists and is active.
Dick
TheDieselStop.Com Photo Editor/Moderator
May '02 F-350 7.3L SC Lariat 4x4 Auto SRW LWB, XM Satellite Radio
June '97 F-350 7.3L Reg Cab XLT 4x4 Auto SRW, CD and XM Satellite Radio
Dick Cutting is offline
Old 01-07-2006, 11:15 AM   #5 (permalink)
Dick
I just did check my email and no email from you.......you must have sent it to the account I can't log in on....hahahaha it figures. At any rate thanks for nothing.
I was unable to post in any forum asking for help because the system would not send me my password........my old password stopped working.
Dan
TreeCo is offline
Old 01-07-2006, 11:29 AM   #6 (permalink)
My Photos: (18)
I e-mailed you a response before I posted my first reply here.
It was e-mailed to the e-mail address you have listed in both profiles. It is the same for both.
Not only did you say you did not receive mine but you did not receive the one the forum software sends as a temporary password.
I guess you may have something wrong with that e-mail account??
Dick
Old 01-07-2006, 11:45 AM   #7 (permalink)
KINGTUT's Avatar
My Photos: (19)
Dick
Dan
Why do you want to be rude as hell when someone is trying to help you. Jeese.
KINGTUT is offline
Old 01-07-2006, 11:46 AM   #8 (permalink)
Dick
Yes it is the same for both and I looked and confirmed I have it correct and it is.
Not likely I have any problems with that email account as I have at least 30 new emails from just this morning.
Nothing here from thedieselstop though.
TreeCo is offline
Old 01-07-2006, 11:57 AM   #9 (permalink)
My Photos: (18)
Well, I just resent the original e-mail again. It does not go thru the TDS mailserver but thru my ISP.
Dick
Old 01-07-2006, 11:59 AM   #10 (permalink)
Dick
I will be using my new ID if that is ok.
I'm back on and all is fine.
Thanks.
Dan
TreeCo is offline
Old 01-07-2006, 04:29 PM   #11 (permalink)
there are some strange things going on around here.
You are correct; vinegar is not as sweet as honey.
NRA member...GUN(s) Owner...Bluegrass performer and festival promoter. Now have an International 9400 Eagle, Cummins N14, 10 speed, 72" mid-rise sleeper. Pulling a 45' Teton 4 axle, triple slide.
http://www.youtube.com/watch?v=GqI14CfACjU (I'm the guy singing lead, w/beard)
"http://www.traditionalbluegrass.us"
bilbo is offline
Old 01-07-2006, 06:03 PM   #12 (permalink)
[/ QUOTE ] Maybe it's the dreaded deadly Duramax virus thats causing all these issues. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
FMT
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 01-07-2006, 09:34 PM   #13 (permalink)
FMT
Good one [img]/ubbthreads/images/graemlins/grin.gif[/img]
Too much junk/toys to mention, ever changing due to too getting bored too quickly. I need a 10 step program!
Want to call? I'm in the book. Want to argue....First explain the square root of negative one....lol
roofeditor is offline
Old 01-08-2006, 02:51 PM   #14 (permalink)
just a suggestion, might check the spam filter settings, and/or the junk folder.
2000 F-350 NVK5, XLT Island Blue 7.3 PSD 3:73LS Reg Cab LB, STOCK EXCEPT:BTS Transmission,Ummmm... Injectors, Home made HUGE Tymar,TC-Lock Mod, CCV mod, Heater-plug mod,6-Pos "Chip", Autometer Z-Series/ISSPro Gauge pod,407hp/849.1FtLbs WEBMASTER Western New York Powerstroke Assoc. http://WWW.WNYPA.ORG
NOT A GIRLY MAN'S TRUCK!!!
XLT Carpet Delete
13.804 @ 96.23MPH 1/4 ---13.686 @ 96.69
8.728 @ 77.70MPH 1/8 ---8.625 @ 78.17
1.931 60' --->1.877
#51
MrPlowJr_EZ_V is offline
Old 01-09-2006, 06:24 AM   #15 (permalink)
My Photos: (18)
Just an update. He is all set now. Received a reply back that he did get my e-mail OK now.
Dick
