Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Off-Topic Discussions
Off-Topic Discussions This is the area for general banter/chat. There are rules for this section, please read the sticky post in the section before participating. The short rules: Only work safe discussions, no religious/political debates!
Closed Thread
Old 08-27-2008, 03:53 AM   #31 (permalink)
Originally Posted by big-angry-hillbilly View Post
International told ford that the E and F chassis cooling system was TOO SMALL TO SUPPORT THE VT365/6.0 POWERSTROKE.
From Day #1.
The head bolts on a 6.4 are larger partially because that engine is designed to run 40+ PSI.
FORD did the powertrain calibrations, not International.
Why does it matter who did the "Powertrain Calibrations" when the failures on the engine are entirely mechanical?
Is the engine leaking oil because Ford wrote the shift tables or something? Do the head gaskets go bad because Ford makes the engine retard power during shifts?
FYI, the 6.0 in the Vans has a lower horsepower rating than than those which are in the Trucks.
checkthisout is offline
Old 08-27-2008, 04:07 AM   #32 (permalink)
ChuckD's Avatar
It like what Ford did with the V8 SHOs. Only was out for a few years knew there was problems, even though Ford didn't make the engine, they should have stood behind the customers. Then got rid of the engine. At $13k for a long block alot of people had a $30k paperweight.
Chuck
1997 F350 7.3 crew cab
1978 Fairmont Futura
2006 Sportster XL883C
ChuckD is offline
Old 08-27-2008, 06:04 AM   #33 (permalink)
RatherBNtheWoods's Avatar
The engine is part of the Powertrain. Your question's about shift points and shift tables makes it look like you're only considering transmission management. Ford also does the engine management. As for why does it matter who does the programming, it's because Ford used an engine barely capable of producing 265~ish HP reliably/dependably and fueled it up to 325~ish HP making it even more likely to break it's "mechanical" parts. Ford also used the fuel filter setup off of the v6. International uses a fuel filter setup more like the 7.3l. The filters on the 6.0 are the ones International uses on the 265 v6. If you take a weak engine with assembly problems and over work it, it won't last as long!
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 100gal aux fuel tank. A real pig from a stop, but give me 10' and she'll lite'em up.
125K miles, 12 injectors, EGR cooler, Fuel pump, 8glow plugs, GPCM, FICM
RatherBNtheWoods is offline
Old 08-27-2008, 12:04 PM   #34 (permalink)
Strokin' 6.0's Avatar
It would be nice if Ford gave you the option of which engine you would like to use as a replacement, when the original one dies.
SSG Fred Lynes
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch Interior
Herrin Hauler Package
5R110 Torqshift
4.10 Trac Lok
Reman'd 6.0L @ 43,956 miles
Reman'd turbo @54,814 miles
Strokin' 6.0 is offline
Old 08-27-2008, 12:22 PM   #35 (permalink)
I'll second that. I would like an 8.0L inline 6 in mine please.
Our Raptor RV
Old 08-27-2008, 12:57 PM   #36 (permalink)
Off Topic
jamboo4 is offline
Closed Thread
» Sponsor Links
»Garage Storage and Cabinets
