Optima Batteries made in mexico - Page 3 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > Off-Topic Discussions
Off-Topic Discussions This is the area for general banter/chat. There are rules for this section, please read the sticky post in the section before participating. Enter at your own risk as some posts in here may be NSFW
Old 12-22-2008, 11:45 AM   #31 (permalink)
My Photos: (5)
Originally Posted by 444-4D View Post
... fit in a group 65 tray that has 1600 CCA's and that can be purchased for 300 bucks.
Read between the lines: Kinetik's website doesn't specify cold cranking amps, just "amps".
It's not a huge stretch of the imagination to suggest that a battery which can deliver 800 cold cranking amperes at -18 degrees C can deliver 1600 amperes at room temperature.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
drcampbell is offline
Old 12-22-2008, 12:02 PM   #32 (permalink)
JW350's Avatar
My Photos: (29)
Odyssey Battery
Yes, Sears sells a rebranded version (Die Hard Platinum) of the Odyssey. I have two of them in my toy hauler and they have performed beautifully. I will probably go with these when I replace my truck batteries next year.
2004 F350, 6.0L TorqShift, SRW, CC, LB, Lariat, 4X4, Built Feb 2004
8" Lift, Fox Shox, 37x13.5x17 Toyo Open Country MT on Weld Evo Velociti XT, 4.88 Gears, MagnaFlow Exhaust, AMP Research PowerStep, Auto Meter Cobalt Gauges (EGT Boost Trans), ScanGaugeII, Firestone Air Bags/Compressor/Tank, BulletProofDiesel EGR Cooler, Valvoline lubricants, Final Charge Global ELC, DieselSite Coolant Filter
JW350 is offline
Old 12-22-2008, 12:12 PM   #33 (permalink)
I understand that but this discussion is about CCA. Here is an example
PHCA: 1,750A at 80°F (27°C); for 5 seconds
CCA: 930A at 0°F (-18°C); for 30 seconds
and I don't know if the voltage drop is the same for both specs. I wouldn't be surprised if the PHCH allowed a higher voltage drop.
444-4D is offline
Old 12-22-2008, 12:44 PM   #34 (permalink)
My Photos: (5)
If I recall properly, the PHCA (Pulse Hot Cranking Amps) specification is still in draft form, but I'd be very surprised if the SAE committee uses a terminal voltage specification different from the one for CCA and CA/MCA when it's finalized.
Old 12-22-2008, 01:23 PM   #35 (permalink)
Originally Posted by TooCoolTwo View Post
Just bought two new Motorcraft batteries for my truck which were manufactured 11-08 in Mexico. Great cranking power!
Also, I have owned smaller yellow top Optimas previously and they did not perform as well as these Motorcraft. Although I liked the maintenance free design of the Optimas much better. More closed hood time. Several others have put the larger yellow top Optimas, which required battery case modications, and they worked out extremely well.
Might mention my truck was also manufactured in Mexico and it has been the best, most trouble free vehicle I have owned. And I have owned quite a few vehicles over my life.
Mike
Optimas are the most overated devices on the face of the planet. IMO of course.
All of your Superduties electrical parts are made in Mexico.
checkthisout is offline
Old 12-22-2008, 11:02 PM   #36 (permalink)
TonkaThunder's Avatar
My Photos: (6)
It looks like I'm mistaken about the batteries being 1600 CCA's. But 1600, 1800, 2000, or if you feel like it 2400 Amps, is still a crap load!!!
03 F-350 DRW Lariat 7.3,4x4 6-Speed, 4.10Gears , 4 inch ProComp lift, BFG AT LT315/75R16, 3 in. spacer between duals.
GT38R 1.0 Housing
Banks Monster Exhaust, w/Turbo Elbow, AFE Stage 2 Cold Air Kit, South Bend Stage 2 Clutch and Cyro'ed Flywheel
DP 80econ -Stuck there for now because someone stole my SCT box
2 Optima Red Tops
Auto Meter Boost and Pyro Gauges
8,200lbs---Cat Scale---Thats me and and 38 Gallons of Diesel
1987 Mustang GT Cobra Clone- crate motor, cage and more suspension than I know what to do with
Loves to run down Vettes and Vipers on the road course
34 Ft Kaufman Solid Deck 2-Car Hauler
TonkaThunder is offline
Old 12-22-2008, 11:20 PM   #37 (permalink)
My Photos: (5)
Originally Posted by TonkaThunder View Post
... But 1600 ... Amps, is still a crap load!!!
Indeed it is, but the "ordinary" car/truck batteries you've been playing with all your life will also deliver that much juice at room temperature.
Old 12-22-2008, 11:36 PM   #38 (permalink)
My Photos: (6)
I beg to differ!!! My Red Tops 800CCA's-1000Cranking Amps. Thats 20%! And from my calculations 80% of 1600 = 1280
GT38R 1.0 Housing
2 Optima Red Tops
Old 12-23-2008, 12:17 AM   #39 (permalink)
You can differ if you want or you could learn somthing. CCA is at 0° for 30 sec, CA is at 32° for 30 sec. The number you are wanting to believe is at 80° for 5 sec.
If you take the battery specs I posted (which is a real battery) and convert them to your battery and use your math that 800 CCA Optima has 1500 PHCA amps.
444-4D is offline
Old 12-23-2008, 10:14 PM   #40 (permalink)
My Photos: (6)
So how do PHCA's work? What are they?
GT38R 1.0 Housing
2 Optima Red Tops
Old 12-29-2008, 07:10 AM   #41 (permalink)
My Photos: (13)
I'm not too happy with Optima right now.I've got a red top that's less than 3 years old, in a car that sits dormant about half the time that won't hold a charge any more. Going to have to take it in, and see how much they'll give me on a pro rated warranty
'92 F-350 Crew Cab dually,7.3 5 spd+ 3 speed Spicer 5831 Brownie, Solid Flywheel w 12 1/4" Kevlar Clutch, ATS turbo, Hypermax Cowl induction, MS Tech Fan Clutch, Custom Aluminum Rodney Red Radiator, 4" Exhaust, Air seat, Western Hauler bed. My Gallery
RLDSL is offline
Old 12-29-2008, 09:36 AM   #42 (permalink)
My Photos: (27)
If you say so. I bought my truck new 16+ years ago and like other guys have said, they're battery eaters. Even the original Motorcrafts only last 3 years like all the others after. I bought two Red Top Optimas 6 years ago and they're still doing great. With the price of diesel, etc, the truck sits now for extended periods at 12 degrees or less temp and the Optimas crank it like it was July.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 12-29-2008, 12:07 PM   #43 (permalink)
My truck isn't a battery eater. I replaced the OE batteries at 4 years 10 months just because of their age not because they were bad. I gave them to a friend of mine and he used them in a couple other vehicles. My second set of Motorcrafts are still in there and are a little over 4 years old now. I'll probably replace them in the spring.
444-4D is offline
Old 12-29-2008, 01:19 PM   #44 (permalink)
Originally Posted by rmcgraw351 View Post
Its official now. I have worked at Optima Batteries for 11 years. In 2000, Johnson controls bought Optima and immediatly began construction of a plant in mexico. We were told that our U.S. plant could not produce enough product so the plant in mexico would be to supply Europe. Slowly but surely, our product lines began being transferred to mexico. Then the week before Thanksgiving, we were told that the U.S. plant will be closed Jan.24 2009. Just thought you all would like to know.
cbs4denver.com - Aurora Battery Maker Moves Operations To Mexico
Sorry to hear about your predicament, it seems like this is what has helped to put us in this mess. Thanks Clinton. good luck to you and hopefully the new year will be kind to you.
2004 F350 6.0, Long Bed,4.5" Full Traction Suspension, SCT tuned, MBRP Turbo Back, REMOVED DUE TO RULES VIOLATIONS, Muffler delete, BFG Velvet Rides
Rock Hardson is offline
Old 12-29-2008, 02:06 PM   #45 (permalink)
I used an Optima in the boat that went bad in a year, I had it replaced under warranty and of course it went bad again a year later.
They just don't hold up the way they say they do. Normal Deep Cycle I can just cook on the charger for a little while and can generally get 3 years out of them, but the optimas were just totally fried.
