My Isspro tranny temp guage stopped working last week. I will check all connections but I need to know how to check the sending unit with my DMM if anyone can tell me.
Thanks, B
Brian, Tucson, Arizona
02 F350 4x4 CREW 7.3 140K, AIS, Isspro pyro, boost & tranny temp pillar pod, Dipricol coolant temp, Isspro EV-2 Fuel Pressure & HPOP, Dieselsite boots, coolant & tranny filters & 203* Stat, 6.0 Tranny Cooler, ITP pre pump tank mod, Bellowed Up Pipes, Riffraff Frx, netbook mount with AE, GPR LED, Stancor, Red Head steering gear, Battery Tender & 2 Marincos.
How cold is it there? Mine never moves off the lower peg on those rare days we get into the 60's here. I did have two episodes where mine "quit working" right - both times it ended up being the crimp connection to the sending unit. Hope that's all yours is.
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
I don't have a crimped connection, it is a plastic connector and I took it apart and cleaned it with contact cleaner even though it looked like new. I know it's not working because it would always get to at least 130 on the highway in cold weather, now nothing.
Do you know what series it is? If it isthe older EV series (with amplifier box under the dash and curved glass lens), please see these troubleshooting instructions: http://www.isspro.com/TROUBLESHOOTIN...leshooting.pdf
Thanks, I did find that info on another site. So far my gauge resistance ohms out perfectly (Ohmed it from the amplifier side to include the wiring up to the gauge). My sender seems to be very close to the values on the chart at a couple of different temps. I have only had the opportunity to check the amp at two temps and once with the sender unplugged. Those readings were not exactly to spec but they were close. I don't have the paper in front of me with everything I wrote down but this weeken I am going to get it good and hot and take some more messurements.
Well after removing the wires on the amp for testing them everything tested good. Put it back together and it started working again. I suspect there was a high resistance connection at the screw terminals on the amp. I know from experience at very low voltages it doesn't take much resistance to stop the flow.
