04 f650 cat c7 poor performance probs - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
Old 06-25-2008, 09:16 PM   #1 (permalink)
jspd234's Avatar
only 45,000 miles on it, also has an allison auto trans. century 21 foot steel car carrier bed. running thru town on flat roads it feels peppy but go up a hill unloaded and the truck slows down to a snails pace. put a car on it and its substantially worse. are these cat c7 just plain gutless or should i look for a problem????
06 F350 xlt sport fx4 srw lb cc 6.0 at afe pg7 cai & accufab polished power elbow, zoodad, dieselsite trans filter n coolant filter, fumoto, 4" turbo back exh. readylift 3.5" lift, 17" atx teflon thugs 315/70 firestone destination mt's. jvc cd dvd sirius head unit with 4 infinity kappa speakers 4 channel infinity amp 10" jl console sub 500 watt jl amp microvision dvd & headrest monitors 4 the kiddies in back!
01 chevy monte carlo ex-nascar southwest tour car raced in the american stockcar challenge(2007 champion!!)
02 sanger V210 black scorpion 330hp 2 fat sacks proflight tower 4 infinity 6x9's rf400 watt amp 12w7 jl sub rf 1001bd clarion amfmcdsirius head unit 4 clarion marine speakers 5 ch hifonics amp 10" bazooka sub encl firing a jl 10w3
09 crf450x
06 drz110 4 tha kid
08 crf150f 4 tha wifey
07 intl 4300 dt466 allison century 612 wrecker alcoa's
04 ford F650 xlt supercab 4dr cat C7 allison century 21 ft carrier alcoa's
97 ford F450 xlt sd 7.3 5 spd century 412 wrecker
jspd234 is offline
Old 07-13-2008, 05:26 PM   #2 (permalink)
DVS
I'm no mechanic. but an F-650 owner. Does it simply loose power, or does it sputter and run erratically?
I've been having an issue with our 2001 F-650 since it was 2 yrs old. I'm thinking it may be attributed to defective fuel tanks, which is blocking fuel flow.
DVS is offline
Old 07-15-2008, 11:09 AM   #3 (permalink)
jspd234's Avatar
doesnt sputter, runs smooth just no power up any type of hills
09 crf450x
06 drz110 4 tha kid
jspd234 is offline
Old 07-21-2008, 04:15 PM   #4 (permalink)
Has this always been a slug or has this just happened? What gears are you running on this truck? What is the GCRW of the whole package? What is the rating on your engine?
JKitterman is offline
Old 08-15-2008, 05:01 PM   #5 (permalink)
jspd234's Avatar
if you start it up n drive it right away, it sputters, but if you let it warm up 4 a few minutes, no sputtering. it has always been a slug. the weight of the truck empty is approx. 13,500 lbs. the gvw is 26,000. it doesnt matter if it is loaded or not, but is even slower with a car loaded on it. cat C7 210hp engine with allison automatic trans.
09 crf450x
06 drz110 4 tha kid
jspd234 is offline
Old 08-15-2008, 05:14 PM   #6 (permalink)
ChuckD's Avatar
Injection Actuation Control would be my guess but I would have to hook up the laptop with Cat ET on it to run some test. It should still be under some warrenty. I would take it in and let them run the test for that and do a cylinder cut out test. Also the HUEI pump may be giving you some problems.
Chuck
1997 F350 7.3 crew cab
1978 Fairmont Futura
2006 Sportster XL883C
ChuckD is offline
Old 08-20-2008, 11:06 AM   #7 (permalink)
jspd234's Avatar
thanks for your help. i called both the ford dealer and the caterpillar dealer. warranty only up to 3 yrs or 36k miles. they want 125 per hr/ 2 hr minimum to diagnose. i'll just drive it til something else goes bad.
09 crf450x
06 drz110 4 tha kid
jspd234 is offline
Old 10-18-2008, 11:18 PM   #8 (permalink)
kaquinn's Avatar
My Photos: (15)
The Cat 210 should pull pretty good! you may have an issue!
OBSession
  • 03' F550 4x4 6.0 CC Lariat utility body:MBPR,BD EGR bye bye,afe stg2 dry, superchip cortex
  • 97' F-250HD 4x4 7.3 CC,SB: AFE stage II, MBRP-ss 4", BD-brake, DP-tunner chip,big oil, mostlysun coast trans, auto meter C2 gauges overhead, fuel?....!
  • 97' F-250HD 4x4 7.3 EC,SB 5 speed
  • 96' F-250 Centurion 4dr bronco 4x4 7.3
  • 96' F-350 4x4 7.3 SC, LB
  • 95' F-350 4x4 7.5 460 CC,LB
  • 94' F350 4x4 7.3 N/A under cont./ referb.
  • 94' F350 4x4 7.3 turbo, dually auto
  • 86' F350 4x4 6.9 4spd dually dump
  • 85' F350 4x4 6.9 w/banks sidewinder
  • 85' F350 2wd 6.9
  • 06' Mercury Mountineer
  • 05'Explorer XLT 4.6 V8
  • 94'Taurus SHO 3.0 5-speed
TRUCKS ARE BEAUTIFUL!
kaquinn is offline
Old 11-05-2008, 01:45 AM   #9 (permalink)
jspd234's Avatar
took it in to shop....
so i was driving and when i stopped, the "service engine soon" light flashed rapidly for about 15 seconds. all guages looked ok, no weird sounds, fluid leaks or loss of power, other than normal. i took it to the caterpillar dealership for diagnosis. i called them for an update and they said so far no issues were reaching out and grabbing their attention. thay will do more diagnosis tomorrow. i will post results whan i hear from them. stay tuned.....
09 crf450x
06 drz110 4 tha kid
jspd234 is offline
Old 11-13-2008, 01:25 AM   #10 (permalink)
jspd234's Avatar
NEVER take your truck or equipment to Peterson CAT in san leandro,ca!!! i dropped off on monday afternoon, they had my truck for 5 days, i left several voice messages on tuesday with no call backs, finally got the service manager after several calls on wednesday, explained the issues with the truck as well as the lack of communication with the shop, he said they are having employee issues and will run some more tests, i called on friday, they say truck was done thursday, said they called me (they didn't). i spoke to a foreman(supposedly) that said they tested injector actuation control, HEUI test, dyno tested, no codes showed up, nothing wrong with truck. then they wanted $750 for diagnostic!!!!! needless to say, i went and got my truck without paying and am currently waiting for a call to see if they want me to pay my bill. i'm not gonna give them 750 thats for sure!!!
09 crf450x
06 drz110 4 tha kid
jspd234 is offline
Old 11-14-2008, 12:15 AM   #11 (permalink)
jspd234's Avatar
UPDATE: ordered a Diablosport extreme power puck for the ol' F6fitty!!! i really hope the claims they make are at least 1/2 of what they say n i'll be happy!!!! we shall see!! i will report back after it gets installed...stay tuned.........
09 crf450x
06 drz110 4 tha kid
jspd234 is offline
Old 11-17-2008, 09:24 PM   #12 (permalink)
kaquinn's Avatar
My Photos: (15)
i ran the EDGE in mine it helped out! nothing like in a pick-up but it was an improvement!
OBSession
  • 85' F350 2wd 6.9
kaquinn is offline
Old 11-17-2008, 09:32 PM   #13 (permalink)
wow, i hope you get out of paying that bill you owe..........
cosmophonic12 is offline
Old 11-18-2008, 09:12 PM   #14 (permalink)
jspd234's Avatar
kaquinn, did that edge unit give you better mpg as well as power?
as for the bill.......they have not contacted me as of yet so i'll just wait for them....
09 crf450x
06 drz110 4 tha kid
jspd234 is offline
Old 11-18-2008, 09:58 PM   #15 (permalink)
kaquinn's Avatar
My Photos: (15)
Hard saying. i never payed any attention! i have never been one to bother with that stuff. when i have tried i alway for get to reset my trip or figure it out be for i take of from the pump. but i would think it would help MPG due to more power= less down shifting. i had 210HP from the factory with a 7 speed. the EDGE was worth the money just in the extra power. it wasn't a through you back in the seat difference but it did wake the truck up!
OBSession
  • 85' F350 2wd 6.9
kaquinn is offline
