1990 474 cid inline 6 fuel system - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
Old 11-21-2009, 04:01 PM   #1 (permalink)
I have always struggled to reprime after filter c/o and had an air bound secondary(injector pump) that only cleared when return check was loosed.
This is in a 1991 F-800 with the 1990 holdover engin so my shop manual doesn't cover my engine (go figure).
I would very much appreciate if anyone could tell me the Lift-pump pressure spec.
This system has a rubber seated check on the return to tank bypass mounted on the P-Pump with a cracking pressure stamped on it 1.8 bar (26 psi).
I do not have any return flow from this check(regulator?) and didn't with an electric pump either.
I am being counseled to mount an electric pump in place of the Lift-pump and if I do, what is normally done with the old lift-pump??
Thanks for bearing with me.
Greg
Last edited by Gbro; 11-21-2009 at 07:45 PM. Reason: Entered p-pump when I ment "Lift" pump
Gbro is offline
Old 11-23-2009, 06:24 PM   #2 (permalink)
Update
I am up and running.
I took the lift pump in to a service center and had it rebuilt. Everything looked good, but check seats were lapped and new hand primer.
Out the door cost on rebuild was $45.00.
I installed and primed the system. I left the return line disconnected until I primed and after purging filters, 3 pumps and I overcame the regulator(check w/26 psi cracking pressure).
The engine fired off after about 5-6 seconds cranking at full throttle.
This is the 1st time ever this truck started without injector line bleeding.
I am one happy bone head mechanic wannabee!
Gbro is offline
Old 12-18-2009, 07:28 PM   #3 (permalink)
nevrenufhp's Avatar
Good to hear it all worked out, and for that cheap! You're not a wannabe anymore.
commuter: 67 F100,300,offy intake,edel carb,274* cam,header
swapping in a Ford/New Holland 6.6(12 valve). Ford engine in a Ford! 6.6 vid: http://www.youtube.com/watch?v=zcflwjpRHUQ
Work truck:'94 IH 4900, DTA466 lightly bombed(#0 fuel plate, timing at 22*, 3 clicks tighter gov springs), Allison MT653, Voith retarder, and straight piped
nevrenufhp is offline
