5.9 Cummins (1994 - 1995) | diesel-world.com
It should be 15-18 psi boost.
94-98 Cummins Diesel 92-06 Dodge VIPER Performance Packages - Superchargers Tuning Cylinder Heads Camshaft Cold Air Induction Dodge Viper
Here is a link with some possibilities for you to help get the turbo turned up to get a little more boost.
Yes, it is the same engine that was used for the dodge pickup trucks.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,00 miles when purchased, now has 149,000 miles, repairs so far: starter, batteries, cps, brakes, tires.
