1999 International DT444 Problems - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
Old 04-24-2008, 09:29 PM   #1 (permalink)
I know this is not a Ford, but it looks like there is ALOT of smart people on here... maybe someone can point me in the right direction.
What I have... 1999 International Bus. It is used by my brothers church group. It has 239k miles on it. They tow a small trailer with some bleachers (for a chior) and a bunch of sound equipment. The bus seems to be ok when it is empty, but once it is loaded and has the trailer on back, it won't get out of its own way.
Here are the codes that are stored (read with an OTC Genysis scanner)...
34
110
164
244
247
254
Scanner also shows 8 psi of backpressure at idle.
The scanner shows it is set a 190hp.
Problems:
The gauges sometimes do not work.
It overheats when loaded, even when on a flat road.
It was nearly impossible to start when it was cold out. It is better now that it is warmer out (I am in Michigan).
It has a new Cam Sensor.
I am an ASE technician, but I really just deal with cars. I know the diesel basics, but am definately not an expert.
A couple questions...
1. Is there a place to get International service information (DTCs, etc)
2. Is there a way to increase the power on this engine?
3. Is there a place I can get a good maintence schedule for a diesel?
4. Suggestions on what to check with the above listed codes and sympoms.
Thanks in advance for any help you can give...
tbalderm is offline
Old 04-25-2008, 10:58 PM   #2 (permalink)
NCheek's Avatar
As far as more technical info on the codes, I can't help you, but if you get slow responses here in the medium duty forum, you might sneak over to the '99 and up powerstroke forum. I would think that you could mod the engine just like any other 7.3 PSD but again, a question for the experts on the other forum.
Hard starting when it's cold out will probably be glow plugs, as far as I know, they are under the valve covers on a PSD.
Good luck with everything.
-Nick
My Daily Driver:
1986 F-250 2WD, Regular Cab, LWB, 6.9, T-19, Sterling 10.25", open 3.55's, XLT Lariat, Texas Sesquicentennial Limited Edition, No Restrictor Plate, manually switched high idle/advanced timing, and an awesome custom shift knob thanks to Bruce Roosa / Koolknobs.
279,000 miles and counting, hoping for a US Gear OD and a Hypermax Turbocharger one day.
My first truck:
1982 F-250 4WD, Extended Cab, LWB, 5.8, C6 to T-19 swap, BW 1345, Dana 44 TTB/Dana 60 Semi Floater, open 3.55's. About four different colors (not counting rust), currently on loan to my little brother. Maybe one day it can be home to a 6.9L too.
Work Truck:
1992 F-700 Flatbed w/ dump, 7.0L BIG BLOCK GASSER, 5-speed trans (Clark?), 26,000 lb GVWR. Rides like a tank
NCheek is offline
Old 04-26-2008, 11:56 AM   #3 (permalink)
spg
It is the same basic motor as the 7.3PSD but the Electronics are all International and are completely different from Fords Electronics. Overheatiog sounds like a Fan or Radiator problem. With 190 HP loaded it will not be very fast but should go down the road ok. You can have International Upgrade the HP electronically but it is expensive and they may require other upgrades to go along with the HP increase. For instance in my truck they also wanted a fan & fan drive upgrade and upgrade the drivehsaft from 1550 to 1710 size when upgrading from 190HP to 210HP.
I don't have any information on reading the codes.
2001 International 4700LP T444E 210HP Fuller Six Speed 3.38
spg is offline
Old 04-29-2008, 11:21 AM   #4 (permalink)
spg
You can order owners manual information on the truck and motor thru International based on your Vin number.
spg is offline
Old 04-29-2008, 12:15 PM   #5 (permalink)
How much was the upgrade? My International dealer is worthless. I have asked several questions and they don't have answers to even the simplest things.
tbalderm is offline
Old 04-29-2008, 05:53 PM   #6 (permalink)
spg
The HP upgrade from 190 to 210 was in the 7 to 800 dollar range a couple of years ago. Basically they just reprogram the truck computer electronics. The Fan and Driveshaft upgrades were seperate. My truck needed the fan clutch replaced anyway but still 200.00 more. Our dealer was pretty good about accepting an invoice that we had done the driveshaft work. If I ever break the 1550 stuff I would be amazed, can't imagine upgrading to 1710 size. That would be a couple grand I imagine for a 4 piece driveshaft, tranny and rear end yokes.
International does everything based on the truck VIN number. They look at original specs for any replacement parts or upgrades. They are not thinking about there trucks from a modified point of view.
What trans do you have in the bus?
spg is offline
Old 05-20-2008, 03:34 PM   #7 (permalink)
http://www.genisysotc.com/06-54.pdf
Are you using the genisys heavy duty scanner? If so, I am surprised that it does not tell you what the codes mean. My suggestion is to call genisys to see if there is a brochure or software that will tell you what the codes mean.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,00 miles when purchased, now has 149,000 miles, repairs so far: starter, batteries, cps, brakes, tires.
DonWarkentin is offline
