2001 Ford F-650 Electrical Problems
Hello, I am working on a 2001 Ford F-650 w/ a Cummins ISB in it. The problem was that intermittently it would continue to run with the key removed and it was also killing the batteries overnight. I was only able to get it to stay running once and was able to pull the Ignition Maxifuse in the underhood Junction Box to get it to shutoff. I checked for a draw at the batteries w/ the key off and found that it did indeed have one and the draw went away when I pulled either fuse 14 or 15 in the cab fuse panel i forget which one it was exactly 14 or 15. This fuse was the "GEM/Interior Light Relay" fuse 10a. With this fuse removed I have no more draw on the batteries, so I let it sit overnight w/ the fuse removed, and this morning the truck fired right up, but w/ the fuse removed I have no electric brake buzzing, no windshield wipers and a few dash lights do not come on. Put the fuse back in and everything works but it is drawing down the batteries. I am leaning toward the GEM module now, We are pretty sure the truck just got a new windshield in Dec. and this problem started shortly after so I suspect water has gotten in there. I was not sure if the GEM module could have anything to do with the truck staying running but it seems like it may. Has anyone had any similar experience, or any experience w/ these GEM modules? If it does need to be replaced does it need to be calibrated by ford or can i just throw the new one in? Sorry for the long post, but this problem is really bothering me. Thanks in advance for any help.
2007 Ford F-350 XLT 6.0L Diesel Reg Cab SRW Stock Red Clearcoat. Line-X Bedliner, Back Rack.
