Re: 2003 ford f650 with a cat 3126e 21' aatac rollback
check your fuel psi at the outlet of the fuel filter base, there is a elbow with a plug on one end and a line going to the cyl head. remove the plug and check fuel psi at idle and wide open throttle. record records and send to me. If your fuel psi drops to zero, it is most likely getting air in the system. Ford has plastic fuel lines. Check all lines for rubbed through areas. Also, make sure your Primary(oem) fuel filter is the right one or may be bad acusing the system to suck air
