5.9 VGT TURBO BRAKE - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
Old 01-07-2007, 01:32 AM   #1 (permalink)
5.9 VGT TURBO BRAKE
anybody wire switch in to run vgt turbo as exhaust brake on newer 5.9 in 650/750
DSRTECH is offline
Old 01-07-2007, 11:48 PM   #2 (permalink)
FleetMan's Avatar
Re: 5.9 VGT TURBO BRAKE
Winnebago is one company that does it in their motorhomes, I'm sure others do also. You might search some Cummins, Freightliner XC chassis or Winnebago data to see how they do it. It does work nice and can be programmed to kick in when you remove pressure from the throttle or when you apply brakes.
Early 99 F250 PSD (XLE4) XLT, Extended Cab, Short Bed, 4X2, BTS Trans/TC, 3.73 Limited Slip, Transfer Flow 48 Gal. Mid-Ship Tank
Western WA - Member since August 2001
FleetMan is offline
Old 01-08-2007, 11:32 PM   #3 (permalink)
Wired in switch and program ecm settings tryed to day does not work great but iglad i done it easy to do
DSRTECH is offline
Old 04-07-2009, 08:20 PM   #4 (permalink)
therabbittree's Avatar
any info or how to..???? my friend is trying to do this with his '07 F650 cummins service truck.
thanks
deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip
http://picasaweb.google.com/therabbittree/Excursion02#
2005 Excursion Eddie Bauer 4x4, 6.0L, Rear Capts. Dark Green
1992 W350, srw, dump flat, 5sp, pods
1996 Passat TDI Wagon, worked
therabbittree is offline
