95 F800 axle broke? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
Old 03-07-2008, 04:47 PM   #1 (permalink)
95 F800 axle broke?
Truck is 95 F800 with 8.3 cummins and allison automatic. Driveshaft turns but truck dosent move is there anything common to check for in the rear axle that might have broke? i believe it has an eaton axle
2008 F-350 ex-cab shortbed lariat 4x4 6.4 torqshift 3.73L.S.dark stone w-two tone pueblo gold trim 8ft Fisher minute mount II
1997 F-350 4x4 DRW XL PSD auto, fisher 9ft minute mount, knapheide util body, 8ft SS buyers sander
Chrisb444e is offline
Old 03-08-2008, 12:26 AM   #2 (permalink)
Pull the axle shafts. Usually the splined end of one of the shafts breaks. If that's not it, you could have broken the pinion.
Louisville Joe, L_Series_Joe, now Louisville_Joe.
Louisville_Joe is offline
Old 03-08-2008, 08:45 AM   #3 (permalink)
thanks i will check that, if only one shaft broke, wouldnt one wheel still turn? or does it free up the whiole axle?
Old 03-08-2008, 09:08 AM   #4 (permalink)
The differential would throw all the power to the broken side axle. So unless You jacked up the back of the truck there would be no movement of either wheel.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline
Old 03-08-2008, 09:54 AM   #5 (permalink)
ok thanks Dr. i will jack the truck and check that
