Re: 95 L8000 8.3L cummins only revs to 1500 rpm
How about checking out the boost line that goes from either the intake manifold or the turbo over to the back of the injector pump. If this line has a leak, it wont let it fuel up. There's also a diaphram on the back of the pump where that same line goes in that can be checked.
commuter: 67 F100,300,offy intake,edel carb,274* cam,header
swapping in a Ford/New Holland 6.6(12 valve). Ford engine in a Ford! 6.6 vid: http://www.youtube.com/watch?v=zcflwjpRHUQ
Work truck:'94 IH 4900, DTA466 lightly bombed(#0 fuel plate, timing at 22*, 3 clicks tighter gov springs), Allison MT653, Voith retarder, and straight piped
