allison auto - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
Old 11-09-2007, 07:44 PM   #16 (permalink)
Re: allison auto
I know what you are going through in that 4700 with the AT545. Feels like a rubber band is connecting the wheels to the engine in 4th huh? RPM stays at governd speed above 40 mph, and the vehicle speed finally catches up to the engine RPM. Have much problem with it running hot? I solved all of them on mine with an MT643.
There is a lockup 545, i don't know the model # I will try to find out. It was only made for a year or two.
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 11-10-2007, 10:59 AM   #17 (permalink)
spg
Re: allison auto
I would appreciate whatever info you can provide. Looking to improve mileage. Mostly highway use while towing a 28' trailer at about 12k. Truck has a 24' box.
What does it take to convert to a MT643? First choice would probably be a lockup 545. Or I have considered changing it to a handshaker.
Thanks Steve
2001 International 4700LP T444E 210HP Fuller Six Speed 3.38
spg is offline
Old 11-10-2007, 09:18 PM   #18 (permalink)
My Photos: (9)
Re: allison auto
My opinion is to put a 10 or 13 speed in it and be done with it. I don't hate automatics but for highway use and avoiding all the calibration hassles and possible expensive failures that an automatic can bring, plus the continued fuel economy penalty even with a lockup converter, I would put a manual in it.
Birken
Birken Vogt is offline
Old 11-26-2007, 11:09 AM   #19 (permalink)
Re: allison auto
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: TheBlueMule</div><div class="ubbcode-body">Just got the truck back home and the transmission is broken in about 4 pieces around the case. The tag says it is a MT643. That is probably what I will end up replaceing it with. I was wondering about the MT 650/653 though and are they realy a true 5 speed? garbage_mechanic said it has a granny gear rather than an OD. Is this tranny a better decision over the MT 643? I already need a new drive shaft so I can get it shortend when I'm getting a new one.
Thanks </div></div> i feel ashamed, and should have known better. the 545 was only behind the non turbo 3208. and only then in earlier years, my bad..
the fleet; ferds ,02'f350,01'f450.the generals ,82'2500, 82'2500 4x4, 82' blazer, 86' blazer ,93'3500, 96'3500, and a 99' 3500hd with 12 valve cummins power. the goats, 90'd250, 91'd350 4x4, 05'3500. all are diesel powered. a list of bigger stuff, as well as gasser's, got lucky, wife comes from a family that collects junk iron too!
navistar45 is offline
Old 12-17-2007, 12:52 AM   #20 (permalink)
Re: allison auto
Well we bought a rebuilt MT-643 with torque converter for "Big Red" Thanks for your help to find out what the heck it was. I'm sure I'll be posting questions if anything doesn't go right. [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img] I'll post when it is up and going. THANKS AGAIN!!
TheBlueMule
1989 F-350 crew cab dually 4x4 7.3 IDI, Banks Sidewinder Wastegated Turbo. Rebuilt E4OD with Transcommand. push button start, 5" straight piped dual bullhorn stacks. New body work and paint. Custom diamond plate interior. Custom built front and rear HEAVY DUTY bumpers, Many Many Mods on the way. Just need more money and time. [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img] fuzzy dice hangin from the mirrior
1990 F-350 Crew Cab SRW 7.3 IDI with ATS turbo. Offroad wheels and tires. E4OD. custom exhaust and turned up pump. New bed and paint.
2001 Custom F-1150 (f-800 w/ f-350) crew cab pickup. "Big Red". 3208 turbo Cat w/ Allison auto. DVD, Navigatin, 6 disc cd changer. back up camera. 22.5 alcoas. dual 150 gallon tanks.
1979 Ford F-250 4x4 Highboy regular cab long bed. 351M 4 speed. Engine, drivetrain, and other upgrageds coming SOON! bought 11-25-07
2008 Mustang warrior edition convertible. FAST!! and 2000 Eddie Bauer Expedition 4x4 5.4 Triton
6 other IDI work trucks and 1 Powerstroke. all with plows and 4x4
ThomasBrooks is offline
Old 07-08-2008, 11:19 AM   #21 (permalink)
Mt 650
While all you guys are at it, I'm looking at a truck with a MT 650. Can any one give me any insite into this tranny?
wawrd1 is offline
Old 10-25-2009, 10:29 PM   #22 (permalink)
I'm trying to mate a MT643 to a Deutz engine SAE #1 bellhousing with SAE 11.5 flywheel. Is there something available from Allison to do this? If these transmissions were used behind a cummins 855, those have SAE #1 bellhousings, right? I wonder if these transmissiona had different housings or used an adapter.
castirondude is offline
