Cummins Intake Air heater Graft Questions? - Diesel Forum - TheDieselStop.com
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
post #1 of 5 (permalink) Old 01-24-2011, 09:35 AM Thread Starter
Ok, been doing research and I believe I have what it will take to put an intake air heater on my F800 with a 5.9 Cummins. Below is a theoretical list of parts and expalnation of use:
Intake heater from a 5.9
6 guage wire for the heavy electrical connections on the relays, heater and batteries.
2 Ford Starter relays
-these units ground through the mounting base, so in theory I think that a power wire to the relays with a momentary switch should activate the relay and power the heater.
Does this sound like it would work? I am not an electrical engineer or even a mechanic by any means, so am needing input from guys with experience. Thanks
2006 Duramax 4x4 X-cab
Auto Tranny
Diablo Predator
1999 Ford F800
5.9 Cummins
Allison Auto
Dillier23 is offline
post #2 of 5 (permalink) Old 01-31-2011, 10:26 PM Thread Starter
Does anyone have any idea as to what I'm talking about?
Auto Tranny
Diablo Predator
1999 Ford F800
5.9 Cummins
Allison Auto
post #3 of 5 (permalink) Old 02-01-2011, 01:37 AM
I'd recommend Dodge heater relays. Ford starter relays may not be strong enough.
Evel486 is offline
post #4 of 5 (permalink) Old 02-13-2011, 10:12 PM
The grid heater pulls 220 amps. One ford relay is good for 200 amps so you should be fine. I've been running one for several years an a Toyota diesel. Just grafted it to the intake. Works like a charm.
Adam
Adam R is offline
post #5 of 5 (permalink) Old 02-20-2011, 05:55 PM Thread Starter
I have an update for my progress on this project. Here's what I ended up using and what it took to get the job done.Truck is a 1999 Ford F800, 5.9 Cummins, Allison AT545 automatic transmission.
Intake heater from a 2001 dodge pickup
Relays from the same truck
2 guage wire from the batteries to the relays
spliced two pieces of 6 guage into the 2ga. to power each relay
ran power to a switch from the splice between the heavy gauge wires
Bolts: the two longer bolts used on the stock intake will work for the shorter side after the heater is placed between the intake horn and manifold. You will need 8m 120mm long and 1.25 pitch threads to install in the longer side of the intake.
Gaskets come from any dodge dealer, they are called air intake heater gaskets, you will need 2 of them.
Heavy duty switch, I used an illuminated toggle rated for 30 amps. Put an inline fuse rated at 25 amps in front of the switch.
Mounted the relays on the upper firewall.
Mounted the switch in the cab under the steering wheel. You can put your where ever is accessible to your needs.
Everything mounted right in and worked great!
First morning the truck was to be used it was around 25f in the morning. Turned the key on, flipped the intake heater switch on for about 10 seconds. Turned the switch off, hit the key and it fired right up. Previously the truck was reluctant to fire if the temps were below 30f. If anyone wants to do this to thier truck and has questions, just ask.
Auto Tranny
Diablo Predator
1999 Ford F800
5.9 Cummins
Allison Auto
  Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
