Engine taking off when put in gear
I have a 99 Ford F800. It has a 5.9 24 Valve Cummins mated to a Allison auto transmission.
Here is what I have going on. The motor starts up perfect, idles smooth and at normal rpm's, the throttle responds perfect and I can run the rpm's up smoothly when its in neutral. As soon as I drop it into any gear, its like the motor is trying to take off. I have to hold it back with the brakes to keep it from going, but the tach is still reading normal idle rpm's. Its basically like I'm power braking it, but I'm not touching the throttle. When I pop it back into neutral, its pretty harsh, and you can tell the engine was trying to go and running at high rpm's. What I did one time when it was in gear was depress the throttle until it moved the tach and I could hear the rpm's increase a little, and then held that position and popped it into neutral and the rpm's were around 1700. The weird thing also is that once you take off and start driving, the trans shifts fine, and it runs like normal down the road. Its just at idle with the trans in gear, something is telling the motor to GO.
It just started doing this the other day out of the blue. Its not throwing any codes. It has a new VP44, coolant temp sensor, air intake sensor, oil pressure sensor, and transmission. I also tried a back up ECM that I have, and it does the same thing, so its not the ECM itself. I've cleaned all the sensor connectors (well, all but the crank sensor by the starter) and the ECM connections and coated everything with dielectric grease. I've tried unplugging a bunch of different sensors but no change.
I'm thinking it has to be some sensor that is telling the VP to increase timing and fuel for some reason when its dropped into gear, I just don't know which sensor would do that. Any thoughts or suggestions on what to check would be greatly appreciated. Is it going to do any good to take it to a shop and hook it to a computer if it isnt lighting up my check engine light? I hate taking it to the shop. Last time I had them install the oil sensor and recalibrate the ECM it ended up costing me $800. My butt still hurts from that one!
1997 Crew F350 4x4, Reman E4OD, Hughes Performance deep trans pan, 3.5 Rancho Lift, Ladder bars, Bilstein 5125's, Skyjacker steering sabilizer, 35" BFG A/T's, ATS Intercooler, AFE style intake, ATS .95 wastegated exhaust housing, 3" downpipe, 4" exhaust, 4.10 Limited Slip, Warn fender flares, Bully adjustable steps, American Racing wheels, Drilled front rotors, Warn manual hubs.
