exhaust brake - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
Old 03-30-2008, 04:33 PM   #1 (permalink)
exhaust brake
Has anyone added a exhaust brake to a 650 with a 5.9 cummins. If so what brand and did you have to change the ehaust valve springs?
Thanks Don
2004 F650 lopro crew cab, hauler body.
cummins 5.9, allison auto
rescue7 is offline
Old 05-04-2008, 11:14 AM   #2 (permalink)
I have a 95 F-800 with a 12 valve 5.9L. I ordered my exhaust brake kit right from the Cummins dealer. I had 20# exhaust valve springs from the factory, I had to install 60#. The exhaust valves came with the kit. The exhaust brake is extremely effective even with the Allison AT 545 automatic transmission.
1993 F-350 4x4 7.3 3.55 E4OD, Fisher MM plow, Skid Steer hauler
geverson is offline
Old 10-18-2008, 11:38 PM   #3 (permalink)
kaquinn's Avatar
My Photos: (15)
i have a 650 w/cat . I installed an in line PAC brake and all it dose is make noise thats about it! I'm told the have a new model you could check that out it just goes in the exaust pipe not engine specific!
OBSession
  • 03' F550 4x4 6.0 CC Lariat utility body:MBPR,BD EGR bye bye,afe stg2 dry, superchip cortex
  • 97' F-250HD 4x4 7.3 CC,SB: AFE stage II, MBRP-ss 4", BD-brake, DP-tunner chip,big oil, mostlysun coast trans, auto meter C2 gauges overhead, fuel?....!
  • 97' F-250HD 4x4 7.3 EC,SB 5 speed
  • 96' F-250 Centurion 4dr bronco 4x4 7.3
  • 96' F-350 4x4 7.3 SC, LB
  • 95' F-350 4x4 7.5 460 CC,LB
  • 94' F350 4x4 7.3 N/A under cont./ referb.
  • 94' F350 4x4 7.3 turbo, dually auto
  • 86' F350 4x4 6.9 4spd dually dump
  • 85' F350 4x4 6.9 w/banks sidewinder
  • 85' F350 2wd 6.9
  • 06' Mercury Mountineer
  • 05'Explorer XLT 4.6 V8
  • 94'Taurus SHO 3.0 5-speed
TRUCKS ARE BEAUTIFUL!
kaquinn is offline
