F650 AC Problem - Diesel Forum - TheDieselStop.com
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
post #1 of 9 (permalink) Old 04-22-2010, 01:36 PM Thread Starter
F650 AC Problem
I have a 2004 F650 with a 5.9 cummins, the AC isn't working in fact I have no power at the compressor. We've checked all the fuses and relays we can find, I don't have an owners manual so I'm shooting in the dark, they all check out fine. I changed the control panel, because when it was cold I had trouble getting the temp to adjust, but that made no difference. Any suggestions would be greatly appreciated.
cuzintiny is offline
post #2 of 9 (permalink) Old 04-22-2010, 02:53 PM
chuckster57's Avatar
Welcome to the Diesel Stop
Have you tried to jumper the pressure switch? If the system is undercharged enough the switch won't allow the compressor to run. I routinely have to disconnect it and use a jumper wire to get the compressor to operate and pull fresh refrigerant after a service. Your charge might have leaked out over time.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 9 (permalink) Old 04-22-2010, 03:34 PM Thread Starter
Yes we tried jumping the pressure switch. Have you ran into a problem where the temp doesn't adjust properly? I just bought this truck a couple of months ago and when it was still cool I couldn't get the temp to go up then after hitting several bumps on our smooth highways it went up but then wouldn't go back down. Now it goes up but I still have trouble getting it to go down.
post #4 of 9 (permalink) Old 04-22-2010, 04:01 PM
No I haven't ran into that issue yet, but it seems like it would have to be in the controls somewhere. I saw in your original post that you changed the control panel. I would maybe start looking at vacum lines. Also maybe your "blend door" actuator or the door itself.
Train Horns:
post #5 of 9 (permalink) Old 04-23-2010, 10:05 AM Thread Starter
Thanks for your help I'll see what I can figure out.
post #6 of 9 (permalink) Old 04-24-2010, 05:49 PM
alexb's Avatar
I have seen many wiring problems on these trucks. Particularily at or about the low pressure cycling switch that is located on the suction line just behind the compressor. It is a round, black connector with 4 pins, but only two wires going in to it. Give it a wiggle and push on it with the engine running and the A/C on to see if the compressor clutch engages.
Ford Senior/Master/Diesel Technician in the Greater Toronto Area. Contact me for help getting your vehicle serviced. Do not contact me with anything pertaining to performance modifications. Proud to be a member of Ford Doctors Diesel Technician Society.
alexb is offline
post #7 of 9 (permalink) Old 04-30-2010, 04:42 PM Thread Starter
You hit it right on the nose!! Thanx alot, the pigtail had been replaced and it had bad connections. Again thanks for your advice.
post #8 of 9 (permalink) Old 04-30-2010, 06:41 PM
alexb's Avatar
No problem. Glad I could help.
alexb is offline
post #9 of 9 (permalink) Old 09-22-2013, 07:07 PM
we found the same problem that the pigtail had been replaced, but when we tried to wiggle it nothing happened. we even tried to touch both ends of the connector with a paper clip to jump it, but nothing happened. any suggestions from here?
empire_kou_inoa is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
