F650 Oil Capacity & Power Steering Fluid Question - Diesel Forum - TheDieselStop.com
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
post #1 of 8 (permalink) Old 01-20-2005, 04:13 PM Thread Starter
I just picked up a 1989 F650 Flatbed Wrecker for a new business I just started. This is my first truck larger than my F350. I want to do an oil change and I don't have any specs on capacity. Does anyone know how many quarts it will take? I was told it has 6cyl Brazilian English diesel. Also, what type of power steering fluid would it take?
My Daily Driver / Backup Tow Rig: 2013 F350 / Crew Cab / Short Bed / Diesel / Lariat Ultimate Package / Single Rear Wheels
My Daily Tow Rig: 2004 F350 / Crew Cab / Short Bed / Diesel / Lariat / Single Rear Wheels
Picture of my rig with my gooseneck dropping off a shipping container at a customer's house:
Allagash is offline
post #2 of 8 (permalink) Old 01-21-2005, 12:08 PM
My Photos: (19)
Re: F650 Oil Capacity & Power Steering Fluid Question
I'm not sure, but you will probably be talking gallons, not quarts. I know the PSD takes about 15 quarts and the 425 Cat in my dump truck at work takes 10 gallons, so I'm sure it is somwhere between these. I know this wasn't much help. Hopefully someone else knows for sure what it is. By the way the engine should be either the 6.6 or 7.8 Ford Diesel.
Stephen
2005 F-250 XL Reg. Cab 4x4 5.4/ZF6/3.73
1994 F-250 XL Reg. Cab 4x4 351/ZF5/4.10
2003 Kubota L3130DT
sbrem is offline
post #3 of 8 (permalink) Old 01-21-2005, 08:38 PM
Well, my DT466 takes ~25 quarts.
Like Stephen said, it's prolly a Ford/New Holland diesel. I used to have a 6.6L in an F-700. Decent little motor, the 7.8L is better, but I forget the oil capacity. I'd think you're in the 20-25 range.
I didn't know my oil capacity on my 466 when I bought it, either, so I just checked the dipstick (it read full), then drained it into a couple 5 gallon buckets. I estimated it to be ~ 6+ gallons, so I just added ~6+ gallons of Shell Rotella and it was darn near full..
Try to fill your new filter(s) with oil, too.
Come back often and let us know how she's running!
'99 F-350XL 4x4 SRW 7.3L chipped, 4" exhaust, Tymar. Billet T/C & shiftkit. 12K hitch. Helwigs. P/H/TTT mirrors, MagHytec rear. Dual F/shocks. 2.5" lift. 285 MT/R's.
99.5 F-450XL 4x4 DUMPTRUCK 7.3L 9' Alum. dump. Front ARB locker, Detroit Rear Locker. Hypermax chip, H2E,.012 Injectors & Taper Core Intercooler, 4" DP & exhaust. Tymar, BTS trans. Airseat. MagHytec pan. P/H/T/TT mirrors. Twin fuelpumps. Dahl-150.
'92 IH-4800 4x4 DUMPTRUCK DTA466, 33K GVW, 7 speed. Fabco 12K 5.38 front, Rockwell 21K 5.38 locking rear, airbrakes, Fabco hi/lo T-case. 11R22.5's, 12'dump w/ air tailgate & Aero electric tarp. Airseats, htd mirrors, pyro/boost guages, 5" stack.
'02 BRI-MAR 12K, 18' trailer.
'98 L-35 Kubota 4x4 TLB
DUKES2FORDS is offline
post #4 of 8 (permalink) Old 01-22-2005, 09:13 AM
My Photos: (19)
We have a 7.8L in a '92 L8000 single axle dump at work. When I first started working there the truck had something wrong with it and it was so gutless and it would barley start when it was even a little bit cold out. But it has been fixed since then. I don't know what the problem was (probably just needed a tune up or someting), but it is soo much better now. A lot more power and in cold weather it is now the best starting truck we have. We pull a lowbed with it, so depending on the equipment being moved, it is still a bit underpowered, but a very decent engine anyways.
Stephen
2003 Kubota L3130DT
sbrem is offline
post #5 of 8 (permalink) Old 01-22-2005, 02:18 PM
My friend is a deisel mechanic for a big steel company. They have dozens of F-800's & L-8000's and other trucks. Some have 3208 CAT's, some have 5.9L's and some have 7.8L Ford diesels.
He likes the 7.8L's the best.
post #6 of 8 (permalink) Old 01-22-2005, 02:54 PM
My Photos: (19)
I would hate to have a 5.9 in that size truck. I realize it will do it, but whats the point? Its an excelent pickup engine, but really doesn't belong in a larger truck.
Stephen
2003 Kubota L3130DT
sbrem is offline
post #7 of 8 (permalink) Old 01-22-2005, 05:02 PM
My Photos: (9)
Check what's in the power steering reservoir, unless it is something weird, it is probably just ATF. Some heavier pumps and steering gears give you the option of using 15W-40 or ATF but say not to mix them. But I would be surprised to find anything but ATF in yours.
Also if it is the same as my 1989 C-8000 and 1982 F-700 it will have a little filter inside the power steering reservoir that might stand changing. Not hard to find or expensive, if you decide to change it and can't cross reference give me a holler and I will dig up the PN.
Birken
Birken Vogt is offline
post #8 of 8 (permalink) Old 02-05-2005, 08:25 AM
nevrenufhp's Avatar
There's an '89 F700 at work with the (210hp rating) 7.8 in it. I can check and see if the sticker says the oil's capacity. They seem to run pretty well when you up the fuel rate too [img]/ubbthreads/images/graemlins/cool.gif[/img].
Just looked today, it doesn't list the capacity....at least I tried to help [img]/ubbthreads/images/graemlins/crazy.gif[/img]
commuter: 08 VW R32, or 67 F100,300,offy intake,edel carb,274* cam,header
Work truck:'94 IH 4900, DTA466 lightly bombed(#0 fuel plate, timing at 22*, 3 clicks tighter gov springs), Allison MT653, Voith retarder, and straight piped
nevrenufhp is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
