F800 HP rating? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
Old 11-18-2007, 02:20 AM   #1 (permalink)
F800 HP rating?
At my work they just bought a '96 F800 (or at least that's what we were told it was).
It has a 12V Cummins and a six speed allison.
How can I find out the HP/TQ rating for the engine in this truck?
'94 F250 XLT- IDI Turbo, 5 speed, 4x4, manual hubs. ATS upgrade, 3" downpipe, 4" exhaust. Autometer pyrometer & boost gauges. More coming.
'87 Thunderbird Turbo Coupe
Lots of mods & pretty quick.
ghunt is offline
Old 11-18-2007, 09:52 AM   #2 (permalink)
My Photos: (9)
Re: F800 HP rating?
Look on the timing gear cover on the drivers side front of the engine, in front of the injection pump, there will be a data plate riveted there. That will tell you the HP and what type of engine it is, then somebody on here can probably tell you the torque rating for that year and model.
Birken
Birken Vogt is offline
Old 11-26-2007, 10:59 AM   #3 (permalink)
Re: F800 HP rating?
what birken is speaking of, is known as the cpl plate. this plate holds all the info about that particular engine. ever go to a cummins shop, this is the first info they will ask for. 96 year engines started at 160hp and went to 230hp. 160/175 were most common in buses and f600's, 190/210 was common in f700/800 apps'. and the higher hp 230, i have only seen one in all my years around these units. when the isb [24v] came in the picture,210/230hp became common. hp and trq rateings are as follows. 160hp/400trq, 175hp/420trq, 190hp/475trq, 210hp/485trq a higher trq 210hp is also avaiable, at 520 lbs. finally the 230hp/605 trq. also if you go to a ford dealer and ask about 5.9 cummins parts, dont be suprised if they carry the ford fd-1060 label.
the fleet; ferds ,02'f350,01'f450.the generals ,82'2500, 82'2500 4x4, 82' blazer, 86' blazer ,93'3500, 96'3500, and a 99' 3500hd with 12 valve cummins power. the goats, 90'd250, 91'd350 4x4, 05'3500. all are diesel powered. a list of bigger stuff, as well as gasser's, got lucky, wife comes from a family that collects junk iron too!
navistar45 is offline
