F800 towing - Diesel Forum - TheDieselStop.com
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
post #1 of 3 (permalink) Old 12-14-2009, 05:33 PM Thread Starter
tanbuddy's Avatar
F800 towing
How do u think a f800 would tow a backhoe and trailer? Total weight would be about 25 000 i would guess.
The truck has a 7.8 diesel wiht 210 hp and 5 speed
tanbuddy is offline
post #2 of 3 (permalink) Old 12-18-2009, 06:19 PM
nevrenufhp's Avatar
It would handle it just fine. If it has air brakes, then you're even one more step ahead. I've loaded one up to almost 40k combined, and it was still ok. The 7.8 is a pretty good engine, just under appreciated. It would haul it better if you turn out the fuel screw. I pointed it out on my youtube video, and details are in the Low Buck Fuel Rate site(they dont let me post the link here).
commuter: 08 VW R32, or 67 F100,300,offy intake,edel carb,274* cam,header
Work truck:'94 IH 4900, DTA466 lightly bombed(#0 fuel plate, timing at 22*, 3 clicks tighter gov springs), Allison MT653, Voith retarder, and straight piped
nevrenufhp is offline
post #3 of 3 (permalink) Old 12-18-2009, 07:05 PM
LTFFNREMTP's Avatar
I also think you will be just fine. The 7.8 is a great little engine, that will work it's butt off all day, even in stock form. We have a fire truck that came with the 7.8 in it, scales somewhere around 32,000 i think. Engine does fine, pulls great and doesn't fall flat on it's face like the 3208 does on a hill. Now if it only had a jake.....
'99 F250 CC-SB 4x4, AFE Stage 2 intake with Pro-Guard 7, Dieselsite coolant filter, DiPricol Full gauges, AIC, On board air + Buell emergency series air horns, Striker turbo timer, Striker I module, Cyclops anti-theft module, TC lockup and 6.0 trans cooler. Powerslot Cryro'd rotors and Hawk LTS pads.
LTFFNREMTP is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
