Have a couple air brake questions - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
Old 12-21-2008, 07:44 PM   #1 (permalink)
Hey Guys, I have a couple questions related to my air brakes.
First, my system seems to loose air while parked, 20psi per day if the truck is unused - Is that normal?
Secondly, where should I tap into the brake system to add a BrakeSmart trailer brake controller? I was thinking about adding a tee at the guage on the primary system side.
2008 F-650 CC pickup, CAT C7 300hp / 900tq, Allison 3000 6-spd auto, 4.33 gears, air brakes, rear air suspension, BrakeSmart
aTX427 is offline
Old 01-03-2009, 09:03 AM   #2 (permalink)
Yes it is normal. Many will lose all air overnight.
http://www.brakesmart.biz/docs/peterbilt330.pdf
BrakeSmart - 877-338-7373
amunderdog is offline
Old 03-27-2009, 08:38 AM   #3 (permalink)
My Photos: (9)
Your best bet is to tee off the stop light switch as the KW diagram shows, if there is only one stop light switch (hopefully). This is because the stop light switch gets its air from both the front and rear air brake signals so if one or the other system is empty due to a failure, the trailer brakes will still come on.
If there are two stop light switches, then you need to use a "double check" valve to the pressure sender. Air brake vendors sell them made for this purpose.
Birken
Birken Vogt is offline
