How do u remove the shifter? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
Old 10-07-2008, 03:19 PM   #1 (permalink)
Hey, I got a C6500 with the CAT 3126 and Eaton 6 speed. I was just wondering if anyone knows how the shifter disconnects from the transmission.
C6500CAT is offline
Old 12-13-2008, 11:46 PM   #2 (permalink)
What are you doing that you need to remove it ? Most common way is to pull the floor boot off in the cab.Looking down on top of the trans you will see the bottom of the shift tower that bolts on to the top plate.Remove the four bolts on the base of the shift tower and lift it strait off and up though the floor.
07,F-250 4X4 6.0 Torqshift, Lariat, Highline package, S/C LWB.
grounder is offline
Old 03-14-2009, 06:14 PM   #3 (permalink)
be sure to cover the hole while you have the shifter out of the trans.
immastrokinnow is offline
