Need help w/ 95 model F450 parking brake - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
Old 04-04-2008, 03:55 PM   #1 (permalink)
farmfuel's Avatar
Hi to all,
I just bought the above truck with a bad parking brake unit (bolts to the back of the transmission.) I wrote on the LT page, but no luck. Hopefully someone on this page will know what I'm talking about.
The truck has a ZF- 5 speed in it, and I recently bought a parking brake unit from ebay. The Ford house has told me to run Mercron V in it, but I can only get less than a pint of fluid in it. Is this all it holds? No wonder these things go out! Also, I notice that there's no drain plug- how do you drain the old oil? Would it hurt to overfill it; seeing as how it's got a breather on the top of the casing?
Thanks in advance for the help.
89 F350 SRW Reg Cab 4X4, 3.55:1, ZF-5 w/ LUK single mass, added Banks sidewinder 12-06. So far so good. 17 mpg using B50 bio blend.
farmfuel is offline
Old 04-19-2008, 03:51 PM   #2 (permalink)
I think it hold 4oz. I wouldn't overfill it, there's only a bearing to lubricate.
Kevooo is offline
Old 04-21-2008, 12:03 AM   #3 (permalink)
Yes, that's all it holds. Do drain it, I guess turn it over while unbolted. It is imperative to check for leaks at every oil change because there is not much to loose before it runs dry.
A.K.A. Sign_man
1988 F-Superduty bucket truck, 7.3 IDI, LuK Clutch, 5 spd, 4.10 rear
http://photos.thedieselstop.com/show...=70062&thumb=1
Phillipmc1268 is offline
