Ford 650/750 Medium DutiesTechnical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
Well it is brake replacement time.
Got ready to pull drum and it is hung on the shoes.
I have the brake pods caged.
Got the drum to move about an inch then no more.
The drums are very worn with big groves visable.
Anyway is there a trick to getting the shoes to draw in farther?
Or just break out the torch and heat the drums.
Any ideas appreciated.
You should be able to back off the slack adjusters. These are the parts the brake chamber pushrods attach to that rotates the "S" cams to activate the brakes. You want the cams to turn the opposite direction they go when the brake pushrod pushes out of the brake chamber. This will adjust the brakes further from the drums.
You can also disconnect the brake chamber pushrods from the slack adjusters and just rotate them further back toward the brake chamber if you wish, although if you do not have to disassemble that part it is just one more step in the process.
I would assume with a Rockwell axle you would have Rockwell slack adjusters, depending on if they have been replaced or not.
Hope this helps out.
Dave / Believer45
__________________ THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
What brand of slack adjusters? Most can be backed off but you have to know the secret handshake to do it.
Dave / Believer45
I had to pull the brake chamber to let some more pressure off the slack adjuster.
It has auto slack adjusters. there is no backing up to them.
Just what Dave said.Meritor Auto slacks have a pawl pin on the side of them thats spring loaded Its about the size of a pennie and When you are under the tk looking at the side of the slack adj faceing you it is right on the side of it..Get a small screw driver gently pry the head of it outwards you are releaseing the lock doing this. is.Now you need to get a small hex 1/4 plug socket.On top of the slack is the manual adjuster.While holding the lock pawl out rotate the adj counter clock wise till the End of the S-cam stops turning inside the slack and the body of the slack itself just starts to move.At this point you have turned the S-cam back to its neutral position and its cupping the shoe rollers inside the drum.Now looking inside the drum you should be able to plainly see the shoes are fully retracted and The brake is fully backed off.If it is a Bendix auto slack adjuster it will have a 7/16 bolthead halfway down the rear of it.This is the manual adj.It has a auto lock inside the slack.To back it off you need to turn it counterclockwise.You will hear the lock pawl skipping inside of it while you do this and feel alot of resistance.This is how it is done and will not hurt anything.After you get the Brake job done and drums and wheels mounted.If the tk has maxibrakes make sure it has 90 psi of air, chock your wheels release the parking brake and adj the slack adj.Or if you have previously caged the springs in the Maxican you are OK.Crank the adj down till the lining contacts the drum.Then back it off 1/2 turn.Any questions on anything please ask I work on rigs for a living and can help you out on any problems or questions .Not to be smart but Spring brakecans are dangerous and can kill you so if you have any doubts ask someone first before doing something you may be unsure of.
