Re: Trans temp mounting in Allison 3000 series
I think transmission oil temperature is broadcast over the CAN bus, therefore no reason for a sender you know [img]/ubbthreads/images/graemlins/wink.gif[/img] You are going to have to make it up as you go I think. I would use one of the filter covers, that way if you screw it up you can get a new one for reasonable. You do not want to go messing with the "pan" on this tranny because it is really the lower valve body. Or else stick it in the convertor out line.
Birken
